Rear Wheel ABS?
Old Mar 9, 2021 | 10:27 AM
dloomis's Avatar
dloomis
Rear Wheel ABS?
Newbie here. Wondering about rear wheel ABS. Can't seem to find anything in any existing threads. How do I tell if the rear wheels have ABS or not. I know that I had changed an ABS sensor on the rear differential (correct term?) a while back. However I only have 2 lines leading the wheel hub/brake location. I assume 1 is for the brakes, and one is for the parking brake. Looking at a 2000 F350 PSD.
Thanks in advance,
Old Mar 9, 2021 | 10:37 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
The rear wheels will have ABS, the front brakes are the ones that may or may not have ABS.
VSS (vehicle speed sensor) is what you changed on the rear differential, which does effect the function of the ABS.
Parking brake is cable actuated and controlled. You should see the cable running along the frame on the outboard driver side I believe.
Welcome to the FTE!
Old Mar 9, 2021 | 10:45 AM
dloomis's Avatar
dloomis
Thanks Sous! I'll take a peek tonight and see if I have them in the front. There, I'm just looking for the wire harness coming from near the top of the knuckle and dust shield, right?
Old Mar 9, 2021 | 10:50 AM
Sous's Avatar
Sous
FTE Emeritus
Yes, my 2000 has the wires cut off and the connectors are just there in order to keep everything sealed up as it should be.
Your welcome and good luck to you!
Old Mar 9, 2021 | 10:58 AM
dloomis's Avatar
dloomis
Thank you sir! And thank you for your service!
Old Mar 9, 2021 | 11:51 AM
Sous's Avatar
Sous
FTE Emeritus
You are very welcome and thank you for saying that.
Let us know what you find and stick around a while if you desire. This is a great place to be on the interwebisphere.
vicv
1983 - 2012 Ranger & B-Series
Jan 24, 2015 04:15 PM
79shovelhead
Oct 16, 2009 04:42 PM
mjbll
1997 - 2003 F150
May 21, 2009 08:08 AM
Hotwheelbill
Mar 21, 2009 11:19 AM
rich burris
Sep 16, 2003 09:16 PM
