My first Dentside
Old Sep 8, 2022 | 10:40 AM
  #31
14 Frosty's Avatar
14 Frosty
Some of the work that I have done over the last 9 months
Engine bay as purchased
Changed steering gear box, cleaned wiring up (PO used lots of spare yellow wiring).
Changed out the water pump as a fan bolt snapped, changed fuel pump
New belts, hoses, the usual suspects, solenoid, ignition box, battery cables, new battery.
Just general all around clean up as I believe the PO had the steering leak for quite some time and just kept topping off so the cast off was everywhere. Good news was no rust until the bed.
As sits now, a small leak from the passenger side valve cover dripping on the manifold. easy fix
Old Sep 8, 2022 | 10:52 AM
  #32
14 Frosty's Avatar
14 Frosty
Brakes were next, Drums were decent, still had over 50% life on them and no grooves in the drum surface so just cleaned up and will be a future project.
Front discs were a different story, needed to replace all of it.
After
Also bent and replaced all lines
Old Sep 8, 2022 | 01:24 PM
  #33
hellgrunt5643's Avatar
hellgrunt5643
Trailering
Man your brake lines look great LOL I had to bend a few when I redid my system and they look like a 5 year old did them
Old Sep 8, 2022 | 03:08 PM
  #34
14 Frosty's Avatar
14 Frosty
I used the copper-Nickle line and then had the coil spring on the outside for added protection for any areas it could rub. The coil spring allowed for easy bending. Basically just taped it to the old line every couple inches and bent where required
Old Sep 8, 2022 | 05:19 PM
  #35
hellgrunt5643
Trailering
Yeah I used the CopNickle as well and it’s easy to work with, just couldn’t make it all nice and pretty, but works better that the old stuff! I’ll keep the above in mind if I need to do anymore. Where did you get the coil spring?
Old Sep 9, 2022 | 10:13 AM
  #36
14 Frosty's Avatar
14 Frosty
I got it off Amazon actually
Old Sep 9, 2022 | 10:54 AM
  #37
14 Frosty's Avatar
14 Frosty
While cleaning up the underside I noticed a hole in my Axle which looks like the PO carved in with a grinder for some reason.
Patched it up and will keep an eye on it
Also refurbished my exhaust as from the muffler back was roached. Put in a flowmaster 50 which sounds pretty good for a single exhaust
Old Sep 12, 2022 | 01:10 PM
  #38
14 Frosty's Avatar
14 Frosty
Original Interior was beige and was very dirty, worn and cracked
Under the panels was a lot of old silicone and sealant, made sure it was cleaned up.
New speakers, new window regulators and new Door panels
Old Sep 13, 2022 | 10:33 AM
  #39
14 Frosty's Avatar
14 Frosty
Next up was the headliner, pressboard had seen better days but all the trim was there
Painted the trim and started sewing up my fabric. Truck will eventually be in the "orange" category as far as color. In order to get the stitches perfect in length I had to go very slow, each line took 5 minutes
Glued down to 1/8" fibre board
Sewed in a pocket to stash a few emergency dollars in or sunglasses. Also added so decorations
Cleaned up the metal and installed some sound/heat shield
You can see in the last pic, used ratchet straps to keep new panel close to where i needed it. Went in ok, but when i looked at the clock once finished realized it was 4 hours to install. Not the easiest one man job
Ended up getting the look I was going for so over all pretty pleased
Old Sep 13, 2022 | 12:23 PM
  #40
snelldawg's Avatar
snelldawg
Where did you get those door panels?
Old Sep 13, 2022 | 12:34 PM
  #41
14 Frosty's Avatar
14 Frosty
LMC, fitment was good, a little playing around to get the door handle lever on but not too bad
Old Sep 13, 2022 | 05:37 PM
  #42
Rubiranch's Avatar
Rubiranch
Looking good. Some of the pictures I thought they were of my truck. LOL
Mine still needs tons of work.
Old Sep 14, 2022 | 11:15 AM
  #43
14 Frosty's Avatar
14 Frosty
They are pretty similar, I like your stance
This is the first time mine has seen daylight in 18 months, a few weeks back
Old Sep 14, 2022 | 05:54 PM
  #44
14 Frosty's Avatar
14 Frosty
Still not settled on a definitive plan for the seat so for now just wanted to put a seat cover on that stayed in place
Sewed in webbing with velcro to tighten up the cover, doesnt move at all now
Its so tight I can barely fold it, but then all i have back there is the stereo box I built for my speakers and amp
Also put down the carpet shown in the last photo. NOS reproductions in Canada, had the heat shield and sound proofing built right in. Was an awesome buy!
Changed out the steering wheel
as I am too tall and the old stock wheel made driving uncomfortable
Old May 24, 2024 | 10:57 PM
  #45
14 Frosty's Avatar
14 Frosty
Did a late night parking lot swap of the beds. I had bought the utility trailer for 200, swapped the beds and sold the "new"" rusty utility trailer for 450. No its officially a two tone
