Dual Tank Issues
Old Mar 6, 2021 | 09:52 PM
Sean Roth's Avatar
Sean Roth
4wd Low
Dual Tank Issues
Hi all,
Wondering if anybody on here can confirm if a 1995 f250 4x4 5.8L V8 EFI has a "fuel reservoir assembly or also referred to as a fuel tank valve selector"? I have looked all over the frame rail and haven't found anything that resembles anything from the picture below. Any help is much appreciated.
Thanks,
Sean
Old Mar 6, 2021 | 10:23 PM
Conanski's Avatar
Conanski
Your truck does not have one of those.
Old Mar 6, 2021 | 10:38 PM
Sean Roth's Avatar
Sean Roth
4wd Low
Thanks, Paul!
Old Mar 7, 2021 | 05:36 AM
tjc transport's Avatar
tjc transport
i ain't rite
by 95 ford switched from selector valve to an in fuel pump valve.
when the fuel pump is powered it opens the valve.
BUT when the pump/valve fails, it will stick in the open position and the return line will fill the opposite tank you are drawing from.
Old Mar 7, 2021 | 06:12 AM
EB5.0's Avatar
EB5.0
There is not. On the frame rail, behind the fuel filter next to the front tank there is a metal box that has the fuel lines from both tank go into it.
Old Mar 7, 2021 | 06:41 AM
My4Fordtrucks's Avatar
My4Fordtrucks
From what I’ve read on this forum, the system changed mid 1990.
What problem are you having that you thought this part is bad?
Old Mar 7, 2021 | 07:21 AM
tjc transport
i ain't rite
i thought it was 92 the change was made, but i was not sure. that was why i said by 95 it had changed.
Old Mar 7, 2021 | 08:47 AM
Sean Roth's Avatar
Sean Roth
4wd Low
Thanks for all the help and information! These failed fuel pump valves, can you buy them or do you have to replace the whole fuel pump?
@My4Fordtrucks The forward tank is not working, when I switch to the front the truck stalls out. Replaced the switch on the dash and when that didn't work I went searching for answers online. Came across the tank selector valve but couldn't see one under my truck. Thankfully, you guys saved from buying one.
Old Mar 7, 2021 | 10:41 AM
tjc transport
i ain't rite
No. When the pump fails, you need to replace the whole assembly.
Old Mar 7, 2021 | 10:56 AM
My4Fordtrucks
Old Mar 7, 2021 | 11:05 AM
Sean Roth's Avatar
Sean Roth
4wd Low
Thanks for all the help, Tom!
Sean
Chays00c
Jan 24, 2021 08:46 PM
ssemones
Oct 7, 2015 07:15 PM
ChristopherN
May 15, 2011 10:55 AM
f-250heavyduty
Apr 24, 2010 07:26 AM
Eric1986
Oct 26, 2007 09:24 AM
