help dual tank problems.
Old Apr 22, 2010 | 04:26 PM
f-250heavyduty's Avatar
f-250heavyduty
i have a 96 f-250 hd 4x4 460 and i run my rear tank cause the gauge works on it. but when i use it, it also pumps gas into my front tank. how do i know? cause my front tank started over flowing one day lol. is there any way to stop this? or what causes it? can i just eliminate the front tank all together? any insight would be much appreciated!
Old Apr 22, 2010 | 04:37 PM
subford's Avatar
subford
You have a bad valve inside your front tank.
This valve may be the high pressure check valve or the return shuttle valve.
To fix it you have to drop the tank (or take the bed off) and replace the Fuel Delivery Module (or Assembly) that is inside your front tank. You could also fix (replace) the sender in the front tank at the same time.
Old Apr 23, 2010 | 04:09 PM
f-250heavyduty
thanks alot sub do you think it could also be a fuel tank selector valve i was told it was right above my front tank is this true? could have the same symptoms as wat ur saying?
Old Apr 23, 2010 | 04:23 PM
subford's Avatar
subford
No it is not true.
But you do not have one.
Your fuel system:
Old Apr 23, 2010 | 04:25 PM
f-250heavyduty
ok sub you have been a gr8 help iam going to buy the midship fuelpump and plastic housing today should all come in one and ill let you know =]
Old Apr 24, 2010 | 12:03 AM
jrodtaclet's Avatar
jrodtaclet
Have a question about the fuel diagram
I would like to only use the rear tank and from looking at the diagram I was wondering if I can clamp the return fuel line to the front tank so no gas will go there and I can drive only on the gas from the rear tank. Thanks
Old Apr 24, 2010 | 07:26 AM
subford's Avatar
subford
Yes you can just unplug both lines from the tank and snap a plug in both lines and tie them up and remove the tank. You will leave the selector switch set to the in use tank at all times or plug in a one tank jumper that will only select the rear tank.
tyler.dunn94
Dec 30, 2016 12:11 AM
Blueriver16
Sep 7, 2016 07:31 AM
91 7three
Oct 22, 2015 10:20 AM
Ex-ChevyOwner
Oct 7, 2015 09:14 PM
oak73
Dec 5, 2006 05:45 PM
