Fuel Filter B.S.
Old Mar 7, 2021 | 01:50 PM
bobv60's Avatar
bobv60
I am not sure on you 2014 but my 2011 did have a clamp bolt that I needed to loosen before I removed the filter.
at about 7 minutes into this vedio they show the clamp bolt
Old Mar 7, 2021 | 02:59 PM
cjssr's Avatar
cjssr
Originally Posted by tradosaurus
I compared both old and new fuel filters and both look identical to the part I pulled out.
The old fuel filter in the engine baby was a bit difficult to remove. I made sure to check that there was no band clamp to loosen.
I did apply a dab of grease on the outside of the engine bay fuel filter to help get it in but still had to use a rubber mallet to slightly tap it down before turning it to lock it in.
I think from now on I will only buy oil and fuel filters from the dealer.
I went thru the same thing changing filters the last time. I had 2 new sets on hand one from Amazon and 1 set from O'Rileys . The Amazon engine filter was like your replacement. Didn't want to fit into the bracket. I had the 2nd set so used that filter and it went into place like the one I took out. Thinking maybe china knockoff but not for sure on the Amazon one
Old Mar 7, 2021 | 07:31 PM
tradosaurus's Avatar
tradosaurus
Thanks for the video. I did shine a light around the fuel filter housing and didn't see a band clamp bolt to loosen but I'm going to check again just to make sure.
I'm wondering if I should buy another engine bay fuel filter and just change it out again?
Old Mar 8, 2021 | 04:11 AM
djousma's Avatar
djousma
if there is a chance you have counterfeit, I'd probably change both out.. fit is likely not the only shortcoming....
Old Mar 8, 2021 | 06:19 AM
slownsy's Avatar
slownsy
I had exactly the same issue with my last fuel filter change and it was purchased from my Ford workshop, I sanded down outside of filter housing with my sander as it was jamming before being fully inserted in housing and was afraid to brake something. I believe that there may have been som quality issues or Ford got som supplies from a different supplier.
Frank.
Old Mar 8, 2021 | 12:57 PM
TJK1's Avatar
TJK1
Just dealt with the same issue last month when changing mine. My filters were from diesel filters online. Been getting all my filters from them for years for my 6.0 and now the 6.7 never had an issue before.
stevestroke01
Jun 27, 2011 10:38 AM
n20
Oct 13, 2009 12:17 PM
61 uni
Nov 22, 2008 08:20 AM
spartamouse1
Apr 5, 2002 06:00 PM
lordconqueror
1983 - 2012 Ranger & B-Series
Sep 8, 2000 01:12 AM
