Tailgate increasingly hard to open
Old May 29, 2015 | 02:26 PM
lwk362393's Avatar
lwk362393
My tailgate is getting increasingly hard to open (and it's not me getting weaker!). I now have to pull pretty hard towards the left side of the handle to get it open, whereas I used to just pull in the center without much effort and it'd fly open. It's so bad my girlfriend can't even open it anymore. Has anyone else experienced this?
Old May 29, 2015 | 02:36 PM
CarlT100's Avatar
CarlT100
I had that problem with my 2000 F-350. I took the panel off of the inside of the tailgate and lubed everything. That solved the problem. I don't even know if these news have that panel; my tailgate is covered by a liner on the inside.
Old May 29, 2015 | 02:37 PM
69cj's Avatar
69cj
Have you ever lubed the mechanisms? White lithium does wonders.
Old May 29, 2015 | 04:14 PM
RigTrash601's Avatar
RigTrash601
I have to agree on lubricating everything really good....
Old May 30, 2015 | 06:13 PM
lwk362393's Avatar
lwk362393
I have not tried lubricating everything, but that sounds like a good idea. I'll give that a shot, thanks!
Old May 30, 2015 | 08:37 PM
CarlT100's Avatar
CarlT100
Please tell us if the lube helps.
Old May 31, 2015 | 05:40 AM
Ford_Doctor's Avatar
Ford_Doctor
I used to have to remove the access cover and lubricate the handle assembly on pre 2008 trucks. I have had newer trucks in that simply needed the left and right latches lubed and that was sufficient to restore function. I used a penetrating oil to loosen them up.
Old May 31, 2015 | 08:44 AM
obwielnls's Avatar
obwielnls
There is an adjustment in there too. I just had to take up a little slack in one side of mine to solve the "Pull handle, push on tailgate, pull tailgate down" issue I was having.
Bill
Old May 31, 2015 | 11:41 AM
Painted Horse's Avatar
Painted Horse
Make sure all your screws are tight on the two ends where the gate latches. If they get a little loose, they alignment is off and it's very hard to operate the opening mechanism.
Old Jun 1, 2015 | 10:00 PM
Bazillions's Avatar
Bazillions
Same thing was happening to me. Passenger side bolt that holds in the latch and cable both was backing out. Tightend it and it was back to normal.
Old Jun 2, 2015 | 08:53 AM
lwk362393's Avatar
lwk362393
Awesome guys, thanks for all the advice. It's raining quite heavily here so I don't think I'll be able to get this done today. Hopefully tomorrow. I'll repost what works.
Old Jun 4, 2015 | 11:24 AM
lwk362393's Avatar
lwk362393
Lubricating, that was the trick! I didn't even have to take off the access panel like I thought I did. Just hit the handle and both latches with some WD-40 and that made all the difference. Don't know why I thought it was something more. Thanks guys!
Old Jun 4, 2015 | 11:33 AM
CarlT100's Avatar
CarlT100
Glad it was a simple fix! Those are the best kind.
Old Jun 5, 2015 | 09:56 AM
porthole's Avatar
porthole
I have had to adjust the pins a couple of times since the truck was new. Left side always seems to be an issue. Sometimes if not level the gat will not open, so while I have the handle pulled I smack the left side of the tailgate to get it to pop open.
And if I am half on - off my driveway, I cannot open the gate at all.
Old Mar 6, 2021 | 11:17 PM
Andrew Taufen's Avatar
Andrew Taufen
Bill
may I ask your steps on doing that adjustment??
