Loose Shifter
Old Mar 5, 2021 | 08:37 PM
Joe Medley's Avatar
Joe Medley
Loose Shifter
1992 F250 automatic trans, got about 180k miles. My shifter is super loose, and is misaligned about halfway, so that when I'm in drive the needle is pretty much touching neutral. I've started to have to jump the solenoid to start it almost every time, the truck won't register when it's in park (it won't roll, but won't let me start it. on certain inclines it will drop back into reverse). I know about the screws on the shifter under the dash, I went and checked mine and they were tight. I've gotten under the truck and looked for bent linkage and don't think I saw anything out of whack, but I'm not an expert and not sure. Is this a problem that replacing the whole column shifter would fix, just taking it out of the column and putting a new one on? Every video I find online is about those screws under the dash. Thank you for any insight!
Old Mar 6, 2021 | 06:47 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Broken shifter tube?
https://www.ford-trucks.com/forums/1...t-of-park.html
https://www.ford-trucks.com/forums/1...am-please.html
Old Mar 6, 2021 | 09:00 AM
tjc transport's Avatar
tjc transport
i ain't rite
shift tube could be broken, but i suspect the bushings under the tube clamps are wore out causing the slop.
MIKES 68 F100
Apr 20, 2015 07:46 PM
r-kid
Mar 4, 2014 11:12 PM
427 fordman
Sep 21, 2009 07:44 AM
scrapyardking
Mar 17, 2008 11:19 PM
Black88GT
Oct 28, 2007 11:16 AM
