Weird trans issue
Old Feb 28, 2021 | 04:12 PM
CrazyJoe6.0's Avatar
CrazyJoe6.0
Weird trans issue
I just put in a used tranny from a guy pulling it from a truck with a blown head gasket ( Same year and everything). I put it in, hooked everything up and she drive beautifully until after about an hour of driving now it’s like its in some sort of limp mode, seems like 3rd gear is the only gear I have and it idles high (roughly 850 RPM) and it’s giving me two DTC codes: ( P0657, P0718 ) and can’t seem to figure out why. Any ideas?
Old Feb 28, 2021 | 04:28 PM
ford390gashog's Avatar
ford390gashog
Did you have the valve body calibration updated to match the new unit? The calibration number is on a sticker on the case and that calibration needs to be updated or else you will have issues.
Old Feb 28, 2021 | 04:29 PM
CrazyJoe6.0
All I did was drop the old and put the new in and topped off the fluid and started driving. So what would I have to do to calibrate that?
Old Feb 28, 2021 | 05:48 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
What year? What engine? What transmission?
The advice above is correct for some models, way off base for others. Since I don't know what you have I can't tell you if it is right or not.
Old Feb 28, 2021 | 06:06 PM
CrazyJoe6.0
it is a 2006 F-250 lariat Fx4 CCSB 6.0 diesel with the 5r110
Old Feb 28, 2021 | 08:36 PM
Mark Kovalsky
There is no valve body calibration that has to be matched to anything.
If it is doing what you said, there are more codes. Those codes will not cause the symptoms you have. Get a better code reader. Forscan is an excellent choice.
Lsawyers
Jan 19, 2020 08:58 PM
Lsawyers
Jan 19, 2020 01:14 PM
mikeycalgary
6.2L V8
Aug 12, 2016 11:23 PM
98-99 trucks
1983 - 2012 Ranger & B-Series
Nov 3, 2011 11:24 PM
mtford
May 11, 2009 07:45 AM
