Trans problems
Old Jan 19, 2020 | 01:13 PM
Lsawyers's Avatar
Lsawyers
Trans problems
I have a 97 f250 powerstroke remanufactured e4od. I started having a hard shift into 2nd and a delayed into 3rd. So I dropped the pan checked the filter and fluid still pretty and red no burnt smell no excessive metal shavings. So I replaced fluid and filter anyways cleaned connectors. Test drive did good no hard shift but a delay in every gear. I drove it for about 2 weeks 48miles round trip to work and home 5 days a week it started shifting better than it ever has smooth in and out of every gear no delayed shifts. That lasted about a month and it started acting like it was slipping through the gears it still pulls and shifts normal but under any kind of hard load rpm just climb like it's slipping but it's still pulling and shifting out. I had my transmission guy test drive it and he said felt like the valve body gasket was losing pressure and I needed a new valve body gasket. So yesterday I replaced the valve body gasket it went smoothly everything was again pretty fluid no debris no burnt smell. It takes gear alot better no delay into reverse or drive nice firm shift into gear it held first gear rpm stayed consistent with the load. It didn't act like it was slipping through the gear. So I took it down the road and after first gear same thing if stomp on it rpm shoot to 3 and hold and it runs through every gear like that. Just like if it was a cvt transmission. I'm completely lost.
Old Jan 19, 2020 | 05:19 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Are there any codes stored? The places that read codes free CANNOT read these codes. You could download Forscan at www.forscan.org for free. You'll need an ELM327 adapter to connect it. I bought mine from Amazon for less than $30. Or you could take it to a good independent shop or a Ford dealer to read the codes.
Old Jan 19, 2020 | 05:26 PM
Lsawyers's Avatar
Lsawyers
I'm using a snap on scanner no codes found
Old Jan 19, 2020 | 06:18 PM
Mark Kovalsky
The only thing I can think of is that you may have loose feedbolts. That will cause a loss of pressure to the clutches.
Old Jan 19, 2020 | 06:31 PM
KingDeleted's Avatar
KingDeleted
Could it be related to the Torque Converter?
Also quick question. how do you change a valve body gasket and get the check ***** in where they are supposed to be? Was the transmission removed to replace the gasket?
Old Jan 19, 2020 | 06:35 PM
Lsawyers's Avatar
Lsawyers
I used small amount of petroleum jelly to hold them in place like alldata told me to do. Is that a wrong method?
Old Jan 19, 2020 | 06:52 PM
Mark Kovalsky
That is an accepted way to do it.
Old Jan 19, 2020 | 07:01 PM
Lsawyers's Avatar
Lsawyers
Where are these feedbolts you speak of?
Old Jan 19, 2020 | 08:58 PM
Mark Kovalsky
They are between the main valve body and the case.
Lsawyers
Jan 19, 2020 01:14 PM
Ryan3332
May 21, 2018 08:19 PM
Scope04
15
Dec 3, 2016 09:42 PM
1993 f150 4x4
Sep 7, 2016 02:19 PM
whatusername
May 4, 2016 09:12 PM
