1978 - 1996 Big Bronco
adjustable camber bushings
Old Oct 26, 2003 | 10:50 PM
carriljc's Avatar
carriljc
Has anyone installed adjustable camber bushings? How tough is it? And how is there a brand you could recommend?
Old Oct 26, 2003 | 11:48 PM
andym's Avatar
andym
If you've never done it before, plan on a weekend to tear both sides apart. Also consider doing ball joints while you're in there, as you have to remove the knuckle to install a new camber bushing anyway.
Old Oct 27, 2003 | 03:17 AM
red bud's Avatar
red bud
actually, you don't have to pull the knuckle if you are lucky enough. Really, all you have to do is pull the nut off the upper ball joint, and take a chisel to the old one, till it comes out. Soak it real good with PB Blaster.
Treacy
May 18, 2019 01:09 PM
Steven Stocki
Feb 26, 2017 09:34 AM
rock2610d
Oct 20, 2015 11:09 PM
Jarryd
Apr 1, 2013 07:36 AM
429rat
May 6, 2002 08:48 PM
