Best key fob
Old Feb 22, 2021 | 05:57 PM
jstihl's Avatar
jstihl
Best key fob
I was just wondering if you guys know of a good key fob for our trucks? The ones that came with my truck when I bought it are aftermarket and you have to be within 10 to 15 ft from the truck in order for it to work. Does this seem normal to you guys? Is there any way to improve the distance?
Old Feb 22, 2021 | 08:16 PM
MountainManRobb's Avatar
MountainManRobb
Do the fobs you have operate the factory keyless entry, or an aftermarket system?
Old Feb 23, 2021 | 05:13 AM
jstihl's Avatar
jstihl
They operate the factory system
Old Feb 23, 2021 | 05:22 AM
Wes444's Avatar
Wes444
Get some generic $3 ones off Amazon/ebay and do the simple reprogramming on them. I got some years ago, work from at least 30-40 to about 100 foot depending on battery freshness. 10 foot you mentioned is horrible, our truck beds are nearly that long.
It's nearly cheaper to buy new ones than buy new batteries. Plus the lock unlock graphic wears off after 5 or 6 years of use and I'm having to tell wife, well if it doesn't unlock when you push the one button................ Push the other one
Old Feb 23, 2021 | 05:45 AM
jstihl's Avatar
jstihl
Hahahaha I could definitely see my wife having the same problem. I thought maybe that was the problem, these remotes were the el cheapos, but you seem to have good luck with them, I will try out another set. Thanks Wes
Old Feb 23, 2021 | 06:13 AM
Wes444's Avatar
Wes444
I just get a 2 pack when I have a battery die then reprogram the 3 in one go when they come in. Maybe way different with the Excursion PATS voodoo
Old Feb 23, 2021 | 07:46 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
I've had similar results as Wesley. Bought two elcheapo FOB's many years ago and programmed them via the instructions Brian42 detailed for us. They work well past the 15 feet or so you describe.
I say a good 50 feet away is average, sometimes more and sometimes less depending on the immediate environment.
Old Feb 23, 2021 | 08:08 AM
CousinCarl's Avatar
CousinCarl
Saw this on another forum:
LINK: https://www.ebay.com/itm/Flip-Key-Sh...Cclp%3A2334524
From China and not sure on the range, but an option to think about maybe. Where the key ring lives looks more stout from pics anyhow. I've had a few break on me there at the eyelet over the years.
Old Feb 23, 2021 | 08:15 AM
Sous's Avatar
Sous
FTE Emeritus
jstihl, I bought these on 8/11/2018 for $6.99.
Elcheapo FOB on eBay.
Also, in case you don't have them, Brian42 wrote up the instructions in a document attached to this post: https://www.ford-trucks.com/forums/1...l#post18133733
Old Feb 23, 2021 | 09:29 AM
jstihl's Avatar
jstihl
Thank you, Yes mine broke at the key ring eyelet so that's why I was hoping to find a better one 👍
Old Feb 23, 2021 | 09:32 AM
jstihl's Avatar
jstihl
Perfect thank you Sous, I was going to go poking around in the tech folder for the instructions but this makes it much easier. I will try a different set of el cheapos 🤠, thanks again
Harleyrdr1
Jan 7, 2021 09:48 AM
Jaime74656
Feb 20, 2016 09:43 AM
EXv10
Mar 4, 2014 09:10 AM
Yaga1973
2009 - 2014 F150
Feb 16, 2014 09:58 PM
Dectek
2004 - 2008 F150
Feb 15, 2007 10:19 AM
