2002 7.3 test IDM
Old Feb 19, 2021 | 08:34 AM
mikenamys's Avatar
mikenamys
2002 7.3 test IDM
Does anyone have a KNOWN good IDM that i can borrow? I will gladly reimburse any shipping and will send it back with a gift card or cash and a little extra as a thank you. NO CODES but am fed up with this damn miss! It HAS to be IDM related...AE shows NO CODES but is now intermittently showing #8 as below required voltage...UVCH are only 22,000 miles old. But all connections are good n tight...In Altoona, PA
Old Feb 19, 2021 | 09:38 AM
Colorado350's Avatar
Colorado350
If you can’t find one Jonathan can test and fix your IDM. Great customer service and extremely quick turn around too.
https://www.dieseltechchatt.com/
Old Feb 19, 2021 | 10:01 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
This might be a long shot, but you could try posting in the PA chapter sub-forum.
https://www.ford-trucks.com/forums/forum182/
Generally an IDM can be considered "good" via a buzz test, but that is not 100% fool proof.
Old Feb 20, 2021 | 04:16 AM
mikenamys's Avatar
mikenamys
[QUOTE=Sous;19741352]This might be a long shot, but you could try posting in the PA chapter sub-forum.
Generally an IDM can be considered "good" via a buzz test, but that is not 100% fool proof.[/QU
Buzz test shows all good...I'll try the PA sub forum...ty
Old Feb 21, 2021 | 07:26 AM
pirschwagon's Avatar
pirschwagon
Have you checked the 42 pin connector for chafing AND pin corrosion?
Old Feb 23, 2021 | 09:37 AM
mikenamys's Avatar
mikenamys
Yessir....Been through every wire on the harness looking for resistance and rub marks....even did a small door cut on my inner fender to allow instant access to the IDM...it was clean and dry and all connections were then lubed with DiGrease...found some rubbed through wires in the typical locations years ago..most places had just started which wasn't bad for the year and the vibration issues with wiring. Hence my frustration. there is just no more a scanner is going to tell me...time for old school mechanic'n...look for the MOST likely culprit. I'd rather spend hours on a right diagnosis than 10 minutes multiple times over chasing the wrong one. Funny tho the older international Lo ride cabs with the 7.3s i have never found a harness issue on...seen it many times on the MaxxForce engines. Most likely going to do the IDM and get INTERNATIONAL UVCH gaskets...all the insulation is pulling away from the plug ends from heat/oil...typical for cheaper ones..They may work but that doesn't mean they work right. All wiring is NOT the same...for all i know a lobe got worn down on the cam...
chrisjrosenbohm
Oct 2, 2020 07:58 PM
78fordman
Apr 25, 2015 10:08 PM
banjopicker66
Sep 22, 2009 06:26 AM
mikey123
May 19, 2005 10:03 AM
jkbk17
Nov 23, 2003 05:42 PM
