Sponsored by: Real Truck
Alternator issue
Old Feb 19, 2021 | 01:48 PM
All fords all the time's Avatar
Alternator issue
I have an 2002 Ford that will not charge I have traced it down enough to know I’m not getting power to the orange wire on the three wire plug witch is suppose to be battery power. I’m guessing it fuseable like E but does anyone know can I supply power to a pin in that wire and make sure it powers the system then. Also anyone know where in the harness fusible link E might be?
thanks
Old Feb 19, 2021 | 02:43 PM
projectSHO89's Avatar
projectSHO89
It would help if you FULLY identified what you are working on....
Old Feb 19, 2021 | 04:40 PM
All fords all the tine
sorry it’s a 2002 Ford F-250 powerstroke
Old Feb 20, 2021 | 02:33 PM
redford's Avatar
redford
FTE Leadership Emeritus
Can you tell us what the voltage is (measured at the battery terminal) with the key off, with the engine idling and with the engine revved up a little (say 2k RPM or so)?
Old Feb 21, 2021 | 04:38 PM
sunuvabug's Avatar
sunuvabug
Originally Posted by All fords all the time
... snipped ... I have an 2002 Ford that will not charge
mmmmm ... click on the "Bad Regulator Wire" link in my signature below and read through that thread. It may be the same issue.
counciller
Apr 17, 2014 09:18 PM
wdglide
Sep 24, 2013 08:59 PM
joe f350
Aug 16, 2013 09:42 AM
newblder
19
Aug 21, 2008 08:29 AM
FordG8tor
Jan 18, 2006 08:33 PM
