I'm under the hood right now installing a DC Power 185 amp alternator.
The stock alt came with a three prong harness plug. The DC Power came with a 4 wire plug. However, both only have two wires. The remaining spots are blanks.
MY problem is the wires are different colors on the new harness. So I am clueless on how to splice it in. It came with zero paperwork.
I bought it from Ed at FICMrepair. I've got a call into Ed but haven't heard back. I called DC Power but had to leave a message.
Plug and play here as well. Same year truck and 190Amp OEM High Output Alternator . IIRC mine had a pigtail with it, is it possible your was just missing th pigtail in the box
Reason: wrong product
My 185 amp alternator was just delivered today and I also have an 04. I just opened it up and it also has a harness adapter. Came with instructions to cut off factory connector and splice in the new one. Maybe its just something with the 04s???
