Engine driven air compressor
Old Feb 19, 2021 | 02:29 AM
ford390gashog's Avatar
ford390gashog
Originally Posted by DarkOverCast
I looked at one on a bus one time, I doubt you could close the hood on a truck the size that compressor was...
The OP has a kurbmaster, last I remember there may be enough room in that engine tunnel because the engine sits low.
Old Feb 19, 2021 | 08:16 AM
Jlwhitt77's Avatar
Jlwhitt77
Thanks for all the great advice fellas. I think I'm just going to install a 5000 watt inverter and go that route. It would be nice to have 110v on the truck anyway.
Old Feb 19, 2021 | 08:18 AM
Jlwhitt77's Avatar
Jlwhitt77
There is this; https://m.youtube.com/watch?v=8OhKpQwTAGU
Years ago I found a picture of someone who mounted a York upright where the factory ac compressor went, and moved the original ac compressor over towards the driver's side so it had both onboard and a/c!
In Texas I would have to do something like that..my last engine I bought came with the York mount I just have to find one...
Electric is honestly probably the way to go, easy to install, simple to hook up, but I like mechanical stuff that aside from catastrophic failures should be very reliable...
Air bags is one of the reasons I'm wanting some air.
Old Feb 19, 2021 | 12:25 PM
Charmalu's Avatar
Charmalu
That is what Forums are for, ask a question, and make a decision on the feed back.
As far as the York`s go, I have read about them from various sites. Lots of off road`ers use them.
Mercedes used them up to around 79, use to see a lot of those years in PNP, but they crush
them as fast as they can.
I sits up high on the right side and a PITA to remove getting to all the bolts.
Then they went with the GM R-4 POS compressor.
Charlie
schoo
17
Mar 15, 2022 09:39 AM
cbzdel
May 23, 2012 08:21 AM
KC8QVO
Oct 10, 2010 04:29 PM
mtufreerider
Apr 6, 2010 12:58 PM
curt9999
Electrical Systems/Wiring
Apr 14, 2009 02:49 AM
