Cold NO start
Old Feb 18, 2021 | 07:52 AM
fordtruckrodder's Avatar
fordtruckrodder
Cold NO start
I hope all are surviving this cold.
My truck had a hard time starting yesterday afternoon. The truck crank perfect yesterday morning with temps in the 20s, but yesterday afternoon, temps in mid 30s, the truck turned over and would not crank. Aftter attempting to start it a few times, 10 volts with key on, I connected jumper cables and still the engine would not fire up. The engine would turn over but not start up. It seemed like it was not getting fuel or maybe like the glow plugs were no heating up. Fuel pressure gauge showed 55 to 60 psi with key on engine off and while turning the engine over. Once the cables were disconnected the truck sat for a few minutes the truck fired right up. On the 1.5 hour trip home the truck ran great icp was reading 1300 to 1700 at 70 mph, voltage was 13.5 to 14.2, fuel stayed around 50 to 60 psi. Once i got home I stopped and started it 5 times without any issues. This morning, after sitting all night, with the temps in the hi 30s the truck fired right up.
Any ideas?
Old Feb 18, 2021 | 08:36 AM
IHateCommieCars's Avatar
IHateCommieCars
Do you have any codes? Not just the CEL, but subcodes? What was the RPM while cranking when it wouldn't start? It can sound fine and still not get over the 150 needed to start. I'd get the batteries load tested. They can also show voltage but still not have enough cranking amps. The voltage on your gauge is coming from the alternator, so it's good, but doesn't tell you the battery voltage, which you need to start.
Old Feb 18, 2021 | 08:54 AM
fordtruckrodder
I currently only have a scangauge. The CEL didn't come on so not sure if there are any codes. Unfortunately I didn't monitor the RPMs so not sure what they were at the time. I have a tester and can test the batteries this afternoon after work. I will post the results once I test them.
I am thinking about getting the FORSCAN app, if I can find the diagnostic adapter I will use the app to check for any codes.
Old Feb 18, 2021 | 09:38 AM
IHateCommieCars
Scangauge isn't the best code reader - I found that it couldn't get transmission codes - but it was decent on the engine PIDs. Worth a look see. Not sure what kind of tester you have, there are differences, and you can research threads in this forum discussing in detail why "load" testing is best. I can't explain it. Forscan is a great code reader.
I'm just thinking that batteries are your only problem, but I'm Bonehead; I recommend a silo for the appropriate quantity of salt grains you should take that with. But, that's definitely the starting place. I expect you'll see a low battery code - or you would have back then. With the charging, then driving, you've done, it's probably reset. However, if there's no other codes, that could be more evidence that it's just a battery issue.
It could still be the starter - starting to go out and dragging more amps. Your batteries could be borderline good, and the starter just too much of a drain to get the 150rpm you need. Cold weather doesn't help any of these things.
Old Feb 18, 2021 | 12:44 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
See my thread here: https://www.ford-trucks.com/forums/1...dows-10-a.html
Batteries STILL suspect. You have to use a vehicle with battery at LEAST as big as the ones in your truck. Hook up and let it charge from the other vehicle. I waiting until the battery on the passenger side was at least up to 13.5 volts. Then have some one run the RPM on the running vehicle run that vehicle up to 2000 RPM then hit the start key in your truck. Wait until the glow plug light goes out then try to start it. DO NOT HIT THE GO PEDAL !
Old Feb 18, 2021 | 01:11 PM
Yahiko's Avatar
Yahiko
You just described the BEST way to start with jumper cables. The longer you let them charge
the less the strain on the cables. Also make sure all consumers are off. Amps can eat power
even with the stereo off. So turn everything off and charge. 5 to 10 minutes seems long but the
start will be much easier and if you have the high idle mod on the running engine use it.
In the way back days I had a guy hit the gas and the back surge blew out all my rear lights.
This was after i has told him to not do what he did. Needless to say I don't do jump starting
much any more. I will call a tow truck and help push. If I know the other driver I will jump
start them.
Old Feb 19, 2021 | 07:53 AM
IHateCommieCars
BTW, if it turns out to be your starter, this would be a good time to consider upgrading to the high-speed starters that came in the 6.4L (maybe the 6.7L too?). If one of your batteries are bad, consider replacing both, although I know how budgets can be.
Old Feb 20, 2021 | 09:03 PM
fordtruckrodder
Well turns out both batteries were weak. One had 8 volts and the other 11 under a load. I replaced both and haven't had the issue again. The batteries were almost 4 years old so guess it was about time to replace anyway. The local Ford dealer had a pretty good deal on the batteries, 3 year free replacement for the same batteries at Napa was only 18 month free replacement near identical prices. Parts guy at ford said Ford will change the warranty next month to I think 1 year free replacement.
BPofMD thanks for the jump start suggestions. The truck we used didn't have batteries as large as mine and I never thought about it. With todays electronics I hate to jump start anything.
6_Myles
16
Dec 12, 2018 06:01 PM
acf6
Nov 27, 2015 06:50 AM
twfish
Feb 18, 2015 09:24 AM
Jmoen7
Aug 3, 2014 09:03 AM
hasteranger
Feb 20, 2013 09:33 PM
