TORQUE PRO FOR WINDOWS 10 ???
Old Feb 13, 2021 | 04:03 PM
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
Trying to download and install Torque Pro on my Windows 10 Laptop. Can anyone tell me if "TORQUE" is the same as Torque Pro ? If not, how the neck do I get Torque Pro for Windows ?
I have a 2005 250 with the 6.0 and a no start, great crank situation and trying to troubleshoot via the suggested items in the Tech Folder to continue. But can't figure out how to get the software to download onto laptop.
Working with GOOGLE sucks !
Old Feb 13, 2021 | 07:41 PM
SlickRick_'s Avatar
SlickRick_
I think it's only available for Android or iOS. Torque Pro is missing a lot of ford specific codes, you would be better off with FORScan which has a windows app.
https://forscan.org/download.html
Old Feb 13, 2021 | 07:58 PM
bismic's Avatar
bismic
You can run it on a Windows 10 machine. You will need an Android emulator. Bluestacks is one such emulator.
https://www.mobileyouth.org/fix-android-authentication-wi-fi-error/
https://pcbeans.com/download-torque-...-and-mac-free/
https://www.bluestacks.com/
Old Feb 14, 2021 | 08:43 AM
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
Thanks Mark...maybe it already worked for me as I didn't start Bluestacks first . Will try again when I get to my laptop. Appreciate the help everyone !
Just looked at the FORScan and bought it from Amazon. Looks much simpler to use/connect. Will help with my MKZ too if I ever need it.! Will be here tomorrow. As it is ICY out there now I can't get out to work on the truck anyway !
Old Feb 15, 2021 | 12:51 PM
JimmyRoach's Avatar
JimmyRoach
I agreed.. I like FORScan for the laptop
Old Feb 15, 2021 | 01:50 PM
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
Question. Just received the Forscan and it will not "connect" to the truck. Do I have to wait until I get the temp license before it will connect? Using Dell laptop and Win10.
Old Feb 15, 2021 | 02:48 PM
JimmyRoach's Avatar
JimmyRoach
mine FORScan worked without the Lic.. just some test can not be done .. it my understanding. their a menu option on top for the connection. to my recall
Old Feb 15, 2021 | 02:53 PM
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
Ummm, wonder why mine won't connect ? Then Scangage works with it plugged into the ODB port so it must be OK.
Old Feb 15, 2021 | 02:57 PM
JimmyRoach's Avatar
JimmyRoach
I had to buy a Bluetooth toggle to go on my laptop to connect to the OBDII device. unless your laptop has connect to Bluetooth devices. may be the problem
Old Feb 15, 2021 | 03:09 PM
JimmyRoach's Avatar
JimmyRoach
Lap top are wi fi
Old Feb 15, 2021 | 03:18 PM
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
USB Laptop connection Using this :
Amazon Amazon
Old Feb 15, 2021 | 05:26 PM
JimmyRoach's Avatar
JimmyRoach
Wow .. that cool.. direct connect. in windows.. does the laptop see the usb device.. may not have the driver.. but does the laptop see a connection ?
Old Feb 15, 2021 | 05:29 PM
2004 F450's Avatar
2004 F450
Originally Posted by BPofMD
You need to download the software to your laptop to use with the adapter.
Here is an interesting read on Forscan's website beware if Chinese junk.
https://forscan.org/forum/viewtopic....=17072&p=59490
Old Feb 15, 2021 | 07:44 PM
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
Thanks 450...not junk. Got that download directly from Forscan site.
Yes Jimmy, laptop sees the devise. Got the driver from Firsca site.
Old Feb 15, 2021 | 09:53 PM
JimmyRoach's Avatar
JimmyRoach
torque pro is the the better one
