Well ****
Old Feb 22, 2021 | 07:47 AM
Zoaz123's Avatar
Zoaz123
Right now I'm just tracking to track down diagrams for the vacuum hoses and any electrics for the hei distributor swap.
Old Feb 22, 2021 | 01:36 PM
FuzzFace2's Avatar
FuzzFace2
Originally Posted by ctubutis
Totally unrelated but I would LOVE a shifter like that one for my T-18, that's because I installed bucket seats from a Jeep Grand Cherokee and the seating position just makes me think a stick bent like that one would be more comfortable for me.
That is on my NP435 transmission and to tell the truth I kind of like the T18 better, truck came with the T18 but was bad and why the swap.
I had to heat and bend it to clear the seat because I have the Advance Adaptor over drive unit in front of the transmission and the NP435 got pushed back 7-1/2"
I know the stick would clear the seat if it was in the normal spot as it did in the truck it came from.
Because its pushed back and the bends the stick is a little taller than it would be and you feel it the first few times you drive the truck but I don't even feel that now.
The other straighter stick is for the over drive and I also bent that to end out where I wanted it.
Dave ----
ps: you cant swap sticks because they attach to the tower differently.
Guess you could cut & weld them to get what you want?
Old Feb 22, 2021 | 01:42 PM
FuzzFace2's Avatar
FuzzFace2
A lot depends on if the truck needs to go through smog?
If not then most of the vacuum lines and what they connect to can be removed.
Should only need vacuum to power brakes, dist. for advance, HVAC, PVC and maybe transmission.
If you do a search you should be able to find what color wire you need to power the HEI dist. from the factory wiring over on the left inner fender IIRC.
Dave ----
Old Feb 22, 2021 | 02:57 PM
Franklin2's Avatar
Franklin2
Feed the HEI with a white/lightblue wire.
Old Feb 24, 2021 | 06:04 AM
Zoaz123's Avatar
Zoaz123
Dave ----
I'm guessing the smog thing is state to state? And as far as hvac, it ain't got it. The blower motor and heater core are melted against the firewall and I dont feel like sourcing a new compressor atm. As far as factory wires go. There aren't really any salvageable ones left.
Sam
May 15, 2011 11:24 AM
ymeski56
20
Aug 31, 2010 10:53 AM
kalawikimaui
Jul 5, 2008 08:40 AM
speedrdr
16
Jan 14, 2008 08:37 AM
desperado_18_2000
Jan 29, 2001 04:44 PM
