Well ****
The inside of my jacket still has some holes where the fire melted the polyester while I was trying to suffocate the fire (It was a desperate attempt, not much logic behind it.)
Throttle cable, Distributor, carb, coil, All the wiring, vacuum lines. Everything burned to a crisp. This was my first ever project car. I have only ever worked on Mopeds before.
So with a new amazon carb, order of parts from rock, roll of vacuum hose from auto zone, box of crimp connectors, and a spool of red 14 gauge wire I set to work.
Cleaned the top of the engine, replaced the lengths of wires that were burned, all the vacuum hoses, threw a carb on it.
Got in and got it to fire (unfortunate choice of words)
Still ran like **** and I had to replace a fuel pump and the tanks a while after. (I signed up on this forum around that time)
It has been just over a year since then I think. Currently, the truck is torn down for a frame-off, but I drove it for the summer beforehand and got it to reliably run for me.
It fought me every step of the way, with a shot axle, shot cylinder heads, leaking every fluid like a sieve, but in the end, it sure felt good to get in, turn the key and drive it.
Don't give up. The victory of getting it running is so much sweeter when it beat you down beforehand.
Mine meant so much to me, that I took it half way around the world to a different continent with me.
Start under the dash, find the computer, unplug the large plug, and work it through the large hole in the firewall. You may have a relay or two with it, let them go through the hole also. If there is a stray wire going into the truck's harness, snip it, note the color and insulate the one left it in the truck. Once you get it through the firewall, when you get to something hooked to this computer harness, unplug it or unbolt it, and continue on till you can take the whole mess out of the truck. The computer harness is mostly separate, except for a couple of power wires that powered the computer system. Make sure to plug that big hole in the firewall with a plate or something. But you can put some smaller holes and some rubber plugs in it before you install it. It's a handy place to run sensors and wiring for aftermarket gauges and choke cables, etc.
I think Dave has removed the feed back computer and wiring but left the feed back carb and its been running good so you may give that a try.
It sounds like the wiring on the right side, starter solenoid, etc., is were the fire was could it have been from the heater box as this is were they all seam to start.
Yes sometimes you have to walk away for a but to "cool off" and when ready jump back on it.
Dave ----
Dave ----
When I bought my flare side I knew the inside was trashed and to get it where I wanted would have been a lot of $$ and I wanted AC.
I bought a parts truck ($400 less motor / doors / tail gate and some dash parts) for the needed parts and then some.
I also used the parts truck bed floor on my flare side, the dual tanks and the complete nose.
I have added carpet since the picture.
So you could end up using a lot of the parts truck and it would pay for its self.
Dave ----
