Stalling When At Stop-No Codes
Old Feb 8, 2021 | 08:13 PM
Big Sky's Avatar
Big Sky
I've been having an issue with my Excursion lately. It seems when I come to a stop and then try to accelerate it stalls. Not all the time, just sometimes. Almost feels like driving a carbureted gasser that feels like it is flooding out. When it does, I throw it in neutral and it fires right back up. I've check Forscan a couple of times and its not throwing any codes. The high pressure oil pump and IPR valve were replaced last summer. The ICP was last changed with a Motorcraft 3 years ago. Doesn't matter if it's warmed up or cold. Thoughts?
Old Feb 8, 2021 | 08:34 PM
BWST's Avatar
BWST
Got Data?
Check for a loose or missing tinnerman nut on the IPR.
Similar issue in this link: https://www.ford-trucks.com/forums/5...om-a-stop.html
Old Feb 8, 2021 | 08:46 PM
Big Sky's Avatar
Big Sky
Thanks-I'll have to check that out...We have nice sub zero weather this week...last week it was 60....
Old Feb 8, 2021 | 09:05 PM
udsuth78's Avatar
udsuth78
The IPR pigtail is always a good suspect also. A close inspection of the wiring harness never hurts.I don't see a tuner listed in your sig, is there one installed?
Old Feb 8, 2021 | 09:43 PM
Big Sky's Avatar
Big Sky
You're the man!!! I checked the valley and sure enough the nut was there, cleaned everything up, grabbed some locktite and put it back on. Thank God the engine still had some heat as it is -5 F. Have a great evening.
Old Feb 8, 2021 | 10:39 PM
BWST's Avatar
BWST
Got Data?
Very cool (so to speak!) Glad you got her fixed up.
Old Feb 9, 2021 | 02:55 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Good job getting it fixed Big Sky!
Also someone please rep BWST for me, I'm in jail.
Old Feb 9, 2021 | 06:25 AM
FordTruckNoob's Avatar
FordTruckNoob
@Big Sky , you can replace that tin nut with a proper 1/2"-20 UNF nut.
I repped BWST for you.
Old Feb 9, 2021 | 06:32 AM
Listor's Avatar
Listor
got it covered!
Old Feb 9, 2021 | 09:01 PM
Big Sky's Avatar
Big Sky
Thanks for the tip on the new nut.
josiewales
Oct 12, 2019 07:43 AM
hhcobra
Jan 2, 2010 08:53 PM
rugermack
13
Jun 16, 2008 01:56 PM
duncannon6
Bronco II
Oct 30, 2006 01:23 PM
