Injection pump?
Old Feb 9, 2021 | 03:23 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
the Return check valve being talked about is the Housing Pressure Regulator... it's mounted on top of the IP and the IP Return line is connected to it....it's normally a Black fitting.
Old Feb 11, 2021 | 05:19 PM
Jacob Wenstrup's Avatar
Jacob Wenstrup
So I checked the valve and it isn’t clogged and it appears to be operating correctly, I pushed on it with a pick while blowing through it and it operated as it should. Any other suggestions?
Old Feb 11, 2021 | 05:38 PM
Jacob Wenstrup
Okay, so I’ve now checked the valve yall mentioned. It was operating correctly. I removed the fuel line from my pump to my filter, it’s getting fuel, I removed my line from my filter to my IP, it’s also getting fuel. I’m not sure how much pressure but there’s fuel and a good amount going to my IP. Any other suggestions? I’m at a loss.
Old Feb 11, 2021 | 06:08 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
OK when you Crack let's say Injector line #1 are you getting good fuel Flow ?
it's best to hold the Throttle at WOT when you do this.
Old Feb 12, 2021 | 02:44 PM
Jacob Wenstrup
Yes I am getting good fuel flow. I’ve checked damn near everything cause I’m really hoping it’s not my IP.
Old Feb 12, 2021 | 04:56 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
so you know all the injectors have good fuel flow ... is smoke rolling out when Cranking ? as it sure should be.
and you know your Glow plugs are working.
and you know you don't have air in fuel issue.
and you know you have good compression....as it starts but will not keep running, but it acts like it is going to WOT
it's sure starting to sound like a Bad IP.
too bad you can't test the Transfer pressure .. you should be getting at least 65 PSI while cranking at 200 RPM
Old Feb 12, 2021 | 05:02 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
You could eliminate the Fuel system by connecting the IP to a small remote tank...but you shouldn't need to do that IF you know that you have good Fuel supply to the IP.
so I would call that a pointless step...BUT some folks like to do that......Personally I just measure the Fuel pressure at the Schrader valve and test the Transfer Pressure on the IP
IF those are good then I generally say the IP has an internal issue.
Old Feb 12, 2021 | 07:49 PM
Jacob Wenstrup
So I finally got it to run, but it’s sounding like garbage and super choppy. My RPMs drop and pick up, it bounces between 800 and 1000 RPM. It sounds horrible and doesn’t want to stay running. I’m trying to add videos but they won’t attach. I’m pretty sure it’s my IP at this point. Either that or injectors. Or my engine is just finally done for.
Old Feb 12, 2021 | 08:11 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
thing is to get it up to temp and see if you can run it up to the Governor ....that should burn all the crap out of the cylinders pretty quick
IF you can get it to that point a Qt of ATF in the filter and let her run 30 seconds then let it sit overnight then drive it like you stole it.
Old Apr 3, 2021 | 07:12 PM
SultanofNACL's Avatar
SultanofNACL
Trailering
"but it's sounding like garbage and super choppy. My RPMs drop and pick up, it bounces between 800 and 1000 RPM. It sounds horrible and doesn't want to stay running."
THAT sounds like what my truck was running like after I had my heads rebuilt and reinstalled. The truck ran like a cut hog, smoked, and the engine seemed 'boggy' but the tack cycling between ~500 and ~1000 RPMs is what alarmed me.
After that, I had taken the top cover and the fuel screw cover (passenger side, two bolts) off of the IP, let the fuel drain out and poured fresh ATF through it to 'flush' whatever could drain through it.
Reattached side cover, filled IP with fresh ATF, reattached top cover, spun new fuel filter on prefilled with ATF and some Howe's, then let the engine sit overnight and ran it again the next day. It still smoked and ran between ~500 and ~1000 on the tach.
Question: Have you run any alternative fuels? Or do you treat your fuel with any additives? Do you check for water in the filter drain? (I'm OCD and will check each tank)
I read that the metering valve in the IP can stick and cause RPM jump like what you described, and ATF should help soften or break up that 'sticky'. I don't recommend removing the IP top cover as you need to make sure it is reinstalled absolutely correctly or runaway can occur.
AnotherChef
Mar 18, 2020 01:43 AM
xDrizzyDre02x
Modular V10 (6.8l)
Sep 13, 2019 08:41 AM
FiznUKa
Apr 20, 2018 06:13 PM
petemcl
33
May 22, 2017 07:56 AM
Kwikkordead
52
Mar 17, 2006 02:54 PM
