Using B&O subs wires for high level input?
Old Feb 6, 2021 | 03:27 PM
Devon McKinney's Avatar
Devon McKinney
2nd Gear
can you or has anyone used the wires that go to the B&O subwoofer for the high level inout on an aftermarket amp? My amp says it can use high or low power inputs for the amp inputs. Alpine MRV-M500 amp. I did the that same thing in my last 2012 f150 with the song system but was curious if it would work the same or not? Has anyone done this? Seems like an easy way to install an after aftermarket amp/subwoofer. TIA!
Old Feb 6, 2021 | 06:06 PM
67L48's Avatar
67L48
Yes. Searching is your friend. Covered many times. Here is one such thread.
Old Feb 7, 2021 | 10:50 AM
GABAR's Avatar
GABAR
PAC-AUDIO.com, Metra, or iData.
Old Feb 8, 2021 | 09:23 PM
34SF's Avatar
34SF
Yup, the outs to the OEM sub work fine as line input to an after market amp.
Old Feb 9, 2021 | 03:05 PM
silver_pilate's Avatar
silver_pilate
I used it as high-level inputs into my Kicker KXA400.1. It works great to the little 8" Kicker CompR. I miss the fullness of my JL stealthbox, but I decided to keep the under seat storage in this truck and just use the stock enclosure, crappy as it is. Overall, pretty tight and clean.
Old Feb 12, 2021 | 02:17 PM
Tricon's Avatar
Tricon
If you use the B&O outputs you'll get a reduced signal at higher volumes and it might cut out lower frequencies. The stock DSP does this to protect the crap B&O speakers at high volume, so it will work, but you'll be limiting your upgraded subs abilities. I would get a full signal from the head unit and run that to your subs. If you want quick and easy though, it'll do.
skohler
Jul 14, 2005 12:33 PM
fordtrucklover94
19
Feb 2, 2005 06:48 AM
2004lariat
Nov 26, 2004 08:08 PM
1979F150
Jul 17, 2002 03:13 PM
chris112lee
Jan 19, 2002 12:02 AM
