Intake plenum removal 95 E150
Old Jan 31, 2021 | 09:37 PM
Tsue's Avatar
Tsue
Unhappy Intake plenum removal 95 E150
I hope to be able to take off the intake plenum this week. Anyone taken the plenum off? I have 5 bolts and the Torx screw out. Not sure what else to remove. I have watched a few videos on older models. I am hoping they help. Also, any idea where the attached came from? I seem to remember it not being connected to anything just wondering how much time I need to spend trying to figure out if it was plugged in somewhere. I can splice it back in; but it’s pointless if it doesn’t have a purpose. I can just tape off the wires.
Thanks in advance
Any ideas?
Old Jan 31, 2021 | 09:41 PM
Conanski's Avatar
Conanski
What motor?
That could be the EEC Test connector, can you post a better picture of the end of the connector?
Old Jan 31, 2021 | 10:30 PM
Tsue's Avatar
Tsue
Originally Posted by Conanski
What motor?
Engine is a 5.0 L. I kinda remember it not being connected to anything
Thanks
Old Feb 1, 2021 | 10:44 AM
Conanski's Avatar
Conanski
Yeah that is the EEC Test connector, best to get that wired back in.
The upper intake has 6 bolts.. one of which is a Torx, and the EGR tube connects between the lower and upper so it has to be disconnected as well. If the tube itself won't break loose from the valve disconnect the valve from the upper intake instead.
Old Feb 1, 2021 | 11:08 AM
Tsue's Avatar
Tsue
Thanks so much. Got 6 bolts so that’s great. Going to remove throttle body today. Then look for more things holding it down
Old Feb 1, 2021 | 11:36 AM
Conanski's Avatar
Conanski
TB doesn't have to come off just the EGR. There is a gasket between the upper/lower that sticks pretty good, chances are it will be destroyed when you separate the two so get a replacement.
Old Feb 1, 2021 | 11:56 AM
Tsue's Avatar
Tsue
Thanks. I will get the egr off and try again
Old Feb 1, 2021 | 10:03 PM
Tsue's Avatar
Tsue
Had to remove this bar. What a PITA
The plenum wiggles now I can’t reach the back bolt on the egr valve. Not sure what my next move will be
JWA
Modular V8 (4.6L, 5.4L)
Sep 26, 2019 04:32 AM
JWA
General Automotive Discussion
Sep 18, 2019 11:00 AM
old28
Aug 22, 2019 07:08 PM
e250VanGuy
Jul 31, 2019 06:18 PM
caltrucker
May 15, 2006 09:29 AM
