Alternator overcharging 01 Ford e350?
Old Feb 1, 2021 | 12:45 PM
Christopher Swindell's Avatar
I’ve got an 01 Ford e350 super duty colt club wagon with 163k miles that I’ve converted to a camper.
I’m about to install an alternator charger for my house(auxiliary) battery and I figured it would be best to test the alternator before I hook it up.
Here are my voltages:
Battery w/ van off: 13.3v
Van on (idle, no load): 14.6-14.8v
Van idle with brights, radio, and heat on: 14.6v
The battery is from 2012. And I’m not sure if that will play a factor. Also, the terminals are a bit funky with a little bit of corrosion (not much.
What steps should I take to troubleshoot this?
Old Feb 1, 2021 | 08:30 PM
Spaznaut's Avatar
Spaznaut
Is that a resting charge or right after you've turned off the van? It needs a bit to come down to its resting voltage.
Old Feb 1, 2021 | 08:34 PM
ford390gashog's Avatar
ford390gashog
The voltage looks normal, the high battery voltage is from a float charge. Check it again after sitting, the running voltages look good.
Old Feb 1, 2021 | 09:05 PM
I just checked it after resting for a few hours and it's registering 13.08v
Old Feb 1, 2021 | 09:20 PM
ford390gashog
That would be in range and correct, are you sure your multimeter is accurate?
Old Feb 1, 2021 | 10:43 PM
I believe it is consistent with the voltmeter and ammeter on my house battery, and it's brand new. So, I'm somewhat sure, but I'll confirm tomorrow. Assuming it's accurate, is that charging voltage and resting voltage ok (even for a 8 year old battery)?
Old Feb 1, 2021 | 11:18 PM
ford390gashog
Yes both voltages are fine.
Feb 1, 2021 04:19 PM
bozomedic
Aerostar
Dec 27, 2005 04:45 PM
balsamgrove
General Automotive Discussion
Jan 1, 2005 08:51 PM
dland
Oct 16, 2002 08:23 AM
moto_dan
Sep 12, 2000 08:37 AM
