I have an old DP intake that I am not going to use, had it for years, not much tied up in it. As I may want to run my Holley 2300 2bbl for a while, I am looking at milling the 4 port holes out so it is an open feed area. I would install a 4x2 adapter to the modified DP intake.
One guy on the site sent me a picture of how he did modified a 4 port square bore setup as shown in picture #1. It leaves the center material & knife edges the material left inside. I would like to do mine a little different.
In picture #2 all the red area would be removed down to the Pimary & Seconary runners. The same adapter would be mounted to this modified DP intake.
I know it is not a C or Clifford but I have it on hand. Comments please, will it work out????
Would the air/fuel mixture change if you remove all of that? Wouldn't the venturie effect (suction) be less in a larger opening? Just asking, I'm not sure at all.
