Sponsored by: Real Truck
headlights not working
Old Jan 31, 2021 | 06:00 PM
Mr.Disprosium's Avatar
Mr.Disprosium
The 99 f250 I bought was missing a bunch of stuff, the front headlight and blinker wires were cut off, there are 3 bundles of wires on each side 2 bundles have 3 wires and 1 bundle has 2 wires, one of the 3 wire bundles are for the blinker and parklamp, the other 3 wire bundle should be for the headlights, but when I wire the bulb to it the headlights and brights both do not work, the blinkers and parklight do work, I'm not sure about the taillights because I had to get a taillight harness from pick n pull and I dont have taillight bulbs yet, I'm not sure what the 2 wire bundle is for but it does get power when I turn on the headlights
Old Jan 31, 2021 | 06:01 PM
Mr.Disprosium
also I forgot to add that all fuses are good
Old Feb 1, 2021 | 02:25 PM
blakeusa's Avatar
blakeusa
Sounds like the wiring for a snow plow set up? not the regular headlights. Did the truck have a plow?
Test wires with 12v test light to see if any are active when the lights are on.
Old Feb 1, 2021 | 10:05 PM
Mr.Disprosium
I'm pretty certain its not a snow plow setup, but the truck has been through 3 owners in its taken apart condition so I cant be 100% sure, 1 wire bundle should be for the blinker, one for the parklight and then one for the headlights, the parklight wire and one blinker wire are hot when I turn on the park light, and when I flip it to headlights they stay on but the headlight wires are not hot like they should be
Old Feb 2, 2021 | 02:06 AM
ridethebigone's Avatar
ridethebigone
The two wire bundle is for the little 194 parking light. One of the triples is for the headlight (hi/low/ground) and the other is for the parking and turn signal. Will need a test light and/or a multimeter to figure them out. Here's a picture that might help. I replaced my headlights with newer style and took a pic when there were off, hope it helps.
Old Feb 2, 2021 | 12:58 PM
Mr.Disprosium
The 2 wire bundle for the park light is hot with the park light switched on, the 3 wire bundle for the blinker and parklight also has a hot wire with the parklight on and the blinker wire was working as it should with the blinker on, but when I flip the switch to headlights the bundle of 3 wires that should be for headlights is not hot with the headlights or brights on
Old Feb 2, 2021 | 05:40 PM
ridethebigone
If both sides are acting the same, then I would work backward to the switch. Something is either cut or disconnected. If the fuse hasn't blown then probably not a short. Electrical problems suck, they're tedious and a PITA to figure out. Sorry I don't have anything more helpful. Google for a wiring diagram maybe?
Old Feb 2, 2021 | 09:55 PM
Mr.Disprosium
Ill go out an trace down the wires tomorrow and check my fuses again, I did blow the blinker fuse because I shorted it out, but I fixed that, maybe I did the same to the headlights and didnt realize it, I also blew the blinker relay by shorting the wires so I need a new of those now
WA_PSD
Feb 2, 2012 10:09 PM
Royals1969
Apr 7, 2011 07:23 AM
STIHL021
Feb 5, 2011 09:08 PM
Leader
Oct 16, 2006 06:02 AM
sancochojoe
Feb 24, 2004 01:59 PM
