390 Would not Start
Old Jan 27, 2021 | 05:41 PM
Ace Zoot's Avatar
Ace Zoot
390 Would not Start
Went for a drive in my 1968 F100 with a 390/c6. Started up and drove 30 minutes and thought to pull in and get gas. After the fill up I went to start and it would barely turn over 2 times. The battery is only 6 months old and all cables are clean. So I try a couple more times when a guy pulls up and offers to give me a jump. Haven't had to do that in 20 years. So after we hook it up I turn the key and it jumps to life. Not a bit slow. So I drive 20 minutes and park it. I wait 30 seconds and try to start it. It fires right up. No problem.
So what could it be? I have never seen this before. I checked the cables and connections and it was all clean. This is a new one on me. Any Ideas??????
Old Jan 27, 2021 | 07:05 PM
Tedster9's Avatar
Tedster9
Just spitballin' here, sometimes when a starter gets long in the tooth, bearings & brushes worn, maybe the armature can get a little catawampus in there, and not want to motor very easily. Draws a lot more current or amps than it should. But it might be an imtermittent thing. If this is what's happening, it will get worse.
This is why sometimes banging on a failing starter with a rock or hammer will get you going again in this situation. Again just spitballin'. Clean cables and ground straps don't necessarily mean electrically good cables, if any of them are factory original, or old enough to vote, they should probably be replaced with quality cables of sufficient gauge size.
Old Jan 27, 2021 | 08:02 PM
UKPR1's Avatar
UKPR1
Ace - how long have you had the truck...20 years? I only ask because is this a new issue on a new to you truck or a new issue on a truck you've owned for 20 years? Here's my 2 cents...was having an issue with heat soak on my 360 which was worsened by long starts because of fuel boil. The cranks literally got slower and slower over the course of 2 or 3 cranks. Switched to ethanol free and a phenolic spacer, the starts got short again and my started stopped struggling.
Old Jan 27, 2021 | 08:09 PM
Ace Zoot's Avatar
Ace Zoot
Had the truck since high school (first car.... uh truck) that would be 1979. Cables are 3 to 5 years old ( from NAPA0 as well as grounding strap. I thought starter too, but it seemed different then the last time the starter went out. I could take starter off and have it tested I think but I would have to remove the header on that side and it is so cold in the garage....
Old Jan 27, 2021 | 08:18 PM
85e150's Avatar
85e150
Headers. Bingo, heat soak. You were stopped long enough for gas to allow the starter to get nice and hot. Once you were moving again, there was enough air flow to keep it fairly cool.
When you got home, parked and waited 30 seconds, there wasn't enough time to heat it up again.
You can easily test the theory. This is very common with headers, not just on FE motors but anything where the headers are close to the starter.
Good luck!
Old Jan 28, 2021 | 11:16 AM
Pcmdub's Avatar
Pcmdub
I agree, it sounds like heat soak. You can purchase a smaller starter that fits like RobbMc Starters, or try to wrap the starter in a heat shield blanket. That will help. It is odd that this is a sudden issue, but it could be because of what others posted, the age of the starter.
Old Jan 28, 2021 | 06:23 PM
JEFFFAFA's Avatar
JEFFFAFA
Also clean battery cable connections at the engine. Including the ground cable that goes from engine to firewall. Especially if you have a leaky valve cover gasket. Oil can get in a connection just like penetrating oil. This could cause an intermittent disconnection.
Pirublues
Mar 29, 2020 02:10 PM
Brynjaminjones
Jan 15, 2019 01:19 AM
don123
6.2L V8
Oct 4, 2017 10:56 AM
ford1995
Nov 27, 2006 07:25 AM
ZRX61
Jan 29, 2004 09:28 PM
