Fuel lines and plentium inserts came early today. I stayed after at the shop and replaced leaking fuel lines and added the inserts which space up the intake spider just enough to make the connection to the turbo a little rough. Noticed a new coolant leak has showed up for the party.
Fired up truck with no noticeable change, while waiting for engine to warm up I shut it off and ran another buzz test. Failed 1,3,5, 7. Jumped out and replaced the plug to the uvch. Fired truck back up and it ran way smoother than it has since this whole mess started, still knocking. By now it’s warm enough for perdels. Every cylinder is under 1 except for #8 which is at 2.25, and #3 is a 4.0.
I decide to drive it home to see if things will smooth out. Runs great at first, then the knock starts sounding funny and the pedal starts feeling like it’s moving away from me. Pretty soon I can’t maintain highway speed anymore, and now we’re costing.
pop the hood and coolant is everywhere. Idm code, two icp pressure codes, and p0340. Towed back to shop, good thing the rig I drove in this morning was still there. So... unsure at this moment where the truck stands, but I do know it’s testing my patience.
Do you know the source of the coolant leak and approximately how much was lost? The IDM code could be retated to the disconnected harness or if you disconnected the + battery cables( does occasionally on mine any way) depending which one it is. The P0340 could be wiring related considering you were in the valley and likely moving the harness around to install the fuel lines. What ICP code sid you get? P1211 is 1 I'd bet how about the other?
It blew the hose off the degas tank. Got it fired up just now, took a while to build icp, there is a lot of pressure coming out of the hose that blew of the tank and the knock is gone. Will check it out more later, seems like a blown head gasket.
The lid on your degas bottle should let off pressure once it reaches its rated pressure. Try running with that cap off or put another one on it and see if it helps.
Degas bottle has nothing to do with your boost...unless your boost is getting into your coolant, which would be indicative of a major problem.
yes that’s why I mentioned head gasket. There is exhaust coming out of the hose that is laying on the leaf spring that blew off the bottom of the degas bottle
7.3's aren't known for blowing head gaskets. Not saying it never happens or that can't be your problem but injector cups are definitely more common. Factor in that ICP pressure was slow to build, which a blown head gasket would have no effect on, it makes icups worth a look at least.
A 20 year old engine with 240k miles. Someone, either the PO or you have gotten your money's worth out of that engine. That knock is not going to heal up. Even if you do make a band aid repair at this point, you still have an engine that is run out.... The truck is at the point of it "nickle and diming" you to death. Next will be the transmission, differentials, steering and front end repairs. If you have a truck you are in Love with..... Rehab it from front to back. If not, sell it to someone who will restore it or just part it out.
Do you have the resources to make this kind of repair ? Mechanical ability, shop, money, time, etc?
Hobo
I just gave my son my '99 7.3. It has 246xxx miles on it. It still runs like a sewing machine and very strong with no blowby from the oil fill cap. Reason I gave it to my son is because I bought myself a 2018 F350 DRW 6.7. My 6.7 only has 15xxx miles on it and if it was down to a 100% trust situation, I would choose the '99 246xxx mile 7.3 without question.
I haven't been following along here so I apologize if this has already been addressed...did you check the blowby with the oil cap method?
