Sponsored by: Real Truck
P0001 and 2 codes
Old Jan 20, 2021 | 02:35 PM
nowhereslow77's Avatar
nowhereslow77
P0001 and 2 codes
Hello folks, apologize if this has been covered but I didn't seem to find anything searching. I'm looking at a 06 F250 Super Duty. 5.4 gas motor with manual trans. 227,000 miles. runs just fine although a little on the loud side. Main concern is a check engine light for P0001 and P0002 codes. I know these are generic OBD codes indicating faults in the fuel volume regulation circuit. I'm assuming other here have seen these codes and or know what the most common (assuming there IS a common) fault/repair/procedure is specific to thiis particular motor. I know these issues with the PCM mounting location on the frame and I AM in upstate NY so corrosion is and issue. That all sais as stated it runs just fine, plenty of power, no limp mode etc. Any and all help is appreciated. Thanks in advance
Bebopjop
6.2L V8
Oct 17, 2020 12:49 PM
ford 55
Jun 20, 2012 11:13 AM
tonefordays
Feb 27, 2012 02:49 PM
ThBgieMn
Jul 21, 2007 07:29 PM
duncannon6
Bronco II
Oct 30, 2006 01:23 PM
