fuel problems?
Old Jun 19, 2012 | 04:22 PM
ford 55's Avatar
ford 55
fuel problems?
1993 F-250 4x4, 5.8 litre, i started having this problem a few days ago, the truck losses power and basically dies out, i have to pull in the clutch and it stays on, but sometimes if will shut off. this only happens sometimes, other times it runs fine. any ideas would help?
Old Jun 19, 2012 | 04:44 PM
Slip ford man's Avatar
Slip ford man
It would help a lot if you could pull any stored codes.
Fuel Injection Technical Library » How To Run a Self-Test
Old Jun 19, 2012 | 06:22 PM
ford 55's Avatar
ford 55
not sure what you u mean by, "stored codes?"
Old Jun 20, 2012 | 11:13 AM
rla2005's Avatar
rla2005
Codes fall into three categories. Codes displayed during the Key-On-Engine-Off (KOEO) tests. A historical listing of codes that happened sometime in the past, these are referred to as Continuous Memory (CM). The third are codes displayed during the Key-On-Engine-Running (KOER) tests.
The definitions can vary depending on when the codes were displayed.
ItsAFord55
Mar 13, 2012 06:51 PM
tva13181
Aug 8, 2011 11:50 AM
duncannon6
Bronco II
Oct 30, 2006 01:23 PM
choppersinc
1983 - 2012 Ranger & B-Series
Mar 1, 2005 08:29 PM
