Need help with a bracket
Old Jan 19, 2021 | 11:04 PM
RJWTX's Avatar
RJWTX
I am building a front bumper for my parent's 2019 F350 Platinum. I had the truck here and jigged it all up but I had to get it back to then due to weather and forgot measure the sensor deminsions. I need to cut out a section and build a bracket for the Adaptive Cruise Control unit. I can drill the holes later but need the height, width, and depth of the plastic cover and the approximate distance between the three bolts in a triangular pattern. Thanks for the help, I ha e searched everywhere and couldn't find any actual measuents, they don't have to be precise just need some simple measurements. I figured I would put it on the left in the center section close to the frame mount.
Old Jan 20, 2021 | 08:42 AM
kehinnc's Avatar
kehinnc
I suggest to get the truck and measure what you need.
Old Jan 20, 2021 | 09:29 AM
RJWTX's Avatar
RJWTX
I would if it wasn't a few hours away lol. I was hoping someone knew the measurements. From a previous build.
Old Jan 21, 2021 | 08:33 AM
Great Danes's Avatar
Great Danes
I can't help with the dimensions, but that is a nice looking bumper. I would like to see it when it's all done.
Old Jan 21, 2021 | 09:26 AM
winglesss's Avatar
winglesss
Welcome to the forum.
Nice work on the bumper.
Why not stop at the local Ford dealership w/ your tape measure and a note pad?
What word is cut in the center section?
Old Jan 21, 2021 | 09:36 AM
ford390gashog's Avatar
ford390gashog
Can't help you with dimensions but I can give you a tip. You need to make sure the adaptive cruise is set to off before you disconnect the sensor or you will get a hard code fault. The sensor needs to also be unobstructed and completely vertical. You will then need to start the calibration procedure and allow it to complete. Try to get the sensor as close to the original spot as possible or it will not calibrate.
rangernut09011980
61
Feb 2, 2024 06:28 PM
NW 150
Aug 5, 2018 09:18 AM
OBX 56
Mar 22, 2018 02:03 PM
strokinout
Apr 10, 2013 11:17 PM
brett3xx
28
Aug 14, 2011 11:21 PM
