My bumper build
Old Jul 13, 2016 | 09:08 PM
rangernut09011980's Avatar
rangernut09011980
My bumper build
PHASE 1 COMPLETE
So far I have the front brackets complete. They are bolt on and I still need to drill some further holes both for the shackles and for a 3rd mounting bolt. Next step will be to get the winch mounts completed and winch mounted where i want it and finish the pattern for the outer shell of the bumper
Old Jul 13, 2016 | 09:12 PM
rangernut09011980
Oh and on another mildly related note if you ever need to "adjust" the nose tip of a frame rail due to an incident involving a steel and concrete gas station post a 3 foot long pipe wrench and 6ft long section of thick walled square tube works pretty well
Old Aug 7, 2016 | 09:11 PM
rangernut09011980
Phase 2 complete starting phase 3
I have the cross beams mounted for the winch plate...I i have the upper panel cut out for step 1 will need to cut a section out of it after i start boxing it in, I also have the risers mounted to the bottom of the upper panel and tomorrow I will be adding mounting tabs for a really cool idea I had of having a removable outer shell to facilitate winch upgrade/ replacement......pics to follow tomorrow
On another note I have ended up throwing out the template idea and have had to begin engineering on the fly.....I am getting the suspicion that my truck has been involved in a collision of some sort Even prior to my gas station mishap.....
Old Aug 9, 2016 | 08:00 PM
rangernut09011980
Completed inner bracket (may be modding this yet on another design change)
1st and 2nd of several steps to building the outer shell. I have the risers welded to the top plate but still need to make mounting plates to attatch it to the inner frame.....somewhere around step 5 i will be taking about 2ft out of the center to make room for the winch..... on a sub note....the brackets only protrude about 8 inches past the frame rail ends...10 would be more ideal due to winch clearance and i didn't realize the screw up until the winch was being mounted (test fit) DO'H
Pic of risers.
Still gotta trim corners but this is the shape i decided to go with
Old Aug 10, 2016 | 11:04 AM
GNR22's Avatar
GNR22
I've gone away from having winches permanently mounted to the bumper. I've switched to going with a cradle mount for a 2" receiver and welding a receiver in my bumpers.
Run power and ground cable to front and rear with a plug, put a lead and a plug on the winch, and you can switch the winch to front or rear on the fly. A lot more useful when you've gone nose first into something and need to get out in reverse.
Old Aug 10, 2016 | 12:24 PM
rangernut09011980
I had thought about that but a 12k winch is friggin heavy
Old Aug 10, 2016 | 08:09 PM
GNR22's Avatar
GNR22
Oh for sure. But this is why I always take a friend when I go wheeling. I always need a spotter, and somebody to help carry stuff.
Old Sep 20, 2016 | 09:13 PM
rangernut09011980
I would be nearly done but the weather had not been cooperating.
Old Sep 21, 2016 | 12:57 AM
The_Drew's Avatar
The_Drew
It's looking good! Actually starting to kinda look like my bumper, you should bolt a brush guard to the top of yours too! Haha
Old Sep 24, 2016 | 05:13 AM
rangernut09011980
I am actually going to be building a brush guard for it as well.
Old Sep 24, 2016 | 07:49 AM
rangernut09011980
Just did some welding this morning
Still gotta get the backsides of them but I'm making progress
Old Oct 19, 2016 | 01:40 PM
rangernut09011980
More pictures
Old Oct 19, 2016 | 02:53 PM
LeoJr's Avatar
LeoJr
How did you get the one edge in the picture squared...grinder? Grinder then a file?
Old Oct 19, 2016 | 05:45 PM
Onions.n.Butter's Avatar
Onions.n.Butter
Your driver doesn't look very qualified to drive your truck
Old Oct 19, 2016 | 06:03 PM
rangernut09011980
Which edge there are alot if them lol
