Tire size question
Old Jun 3, 2019 | 06:11 AM
slowfarmer's Avatar
slowfarmer
Tire size question
Question for the tire experts out there. I bought my 17 F250 6.7 used came with cooper discoverer st maxx tires in size 285/70 r17. It is time to replace them and I noticed door jam sticker says stock tire size is 245/75 r17. I know the current tires I have are wider and have a taller sidewall (plus they are heavier obviously).
This is my farm truck and I spend a lot of time driving and moving my chicken coops through pasture. Also tow mild loads a few times a month and have ~2000lb of water in the bed often.
I think I am set on getting another set of the st maxx or goodyear wrangler duratrac. My question is should I stick with the 285/70r17 or go back to stock size 245/75r17 for what Im using the truck for? I think I'd get better mpg with the smaller tires (and they are a little cheaper) but would I lose a noticeable amount of traction offroad? Thanks for your help
Old Jun 3, 2019 | 06:38 AM
pdose's Avatar
pdose
I would want the extra traction in a pasture with the extra weight. That stt maxx is pretty aggressive.. and probably fitting for the type of condition you have. I have a 6.7 and wouldn’t consider driving in a pasture on the stock tires
Old Jun 3, 2019 | 07:26 AM
Joe T's Avatar
Joe T
I think that is a “33 inch” tire. Not really all that big on these trucks.
I would research some high traction tires in similar sizes. Weight and reviews.
You can try a cross terrain like the Ridge Grappler (I like mine so far) or an All Terrain if you want more mpg and road manners.
Old Jun 3, 2019 | 07:33 AM
Greg Hamilton's Avatar
Greg Hamilton
I would stick with the 285/70 r17. I think the stock tires are too small myself. We're running a lot of the stt max on our trucks at work and the guys seem to be pretty happy with them. If you're happy with the way they've been performing, I'd stick with them. Personally, I'm a BFG KO2 fan. That's all I run.
Old Jun 3, 2019 | 09:32 AM
Wandell877's Avatar
Wandell877
Personally, I think that 33's are too small looking on these trucks. I definitely wouldn't go smaller than what you have now.
Old Jun 3, 2019 | 11:00 AM
slowfarmer's Avatar
slowfarmer
Thanks for all the advice. I will stick with current size or maybe a bit bigger. I'll look into those grapplers and ko2 as well
Old Jan 21, 2021 | 10:03 AM
Boxwood Bumper's Avatar
Boxwood Bumper
It has been a little while since I have read the forum so you may have already gotten your tires.I spent some time researching mine and before putting these on my truck. I have been happy with their performance and wear. I was trying to get a modern tire that resembled the original size (tall and narrow) the best. I could not find any information on rolling resistance though. I can take a closer picture of the tire if it helps.
T235/85R-16 MICHELIN XPS TRACTION E
CR172
2015 - 2020 F150
26
Mar 6, 2018 02:56 PM
brandon_oma#692
Jul 14, 2009 03:04 PM
drew1485
Feb 22, 2008 08:33 PM
emptyd
Sep 23, 2007 12:59 AM
toolboxjunky
Jun 21, 2006 09:13 AM
