Sponsored by: Real Truck
Shifting
Old Jan 19, 2021 | 01:57 PM
Angel1973's Avatar
Angel1973
Shifting
I have a 1999 F359 super duty I just bought and it shifts hard. Speedo works fine as everything else does and it throws the PO500 code so I changed the VSS but still the same problem. The previous owner had a mechanic replace the computer out of another F350 and it's done this ever since I guess. What could it be
Old Jan 19, 2021 | 03:45 PM
super 6.8's Avatar
super 6.8
Did you disconnect the battery after replacing the VSS?
Old Jan 19, 2021 | 06:21 PM
Angel1973's Avatar
Angel1973
I don't recall if I did right then or not but have several times since
Old Jan 19, 2021 | 06:59 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Why do you need to do that? If the problem is not present the hard shifting won't be present and the code will clear.
P0500 doesn't mean replace the sensor. It means the PCM isn't seeing the signal from the sensor. Sometimes that is from a bad sensor, but quite often it is from a damaged wire between the PCM and the VSS.
Old Jan 19, 2021 | 07:02 PM
Angel1973's Avatar
Angel1973
Another question the wires going to the VSS, Is either one a hot wire?
Old Jan 19, 2021 | 07:27 PM
Mark Kovalsky
No, neither one.
Old Jan 19, 2021 | 07:30 PM
Angel1973's Avatar
Angel1973
So what do u recommend my next step be
Old Jan 19, 2021 | 09:13 PM
Mark Kovalsky
Check continuity of each wire from the VSS to the PCM. Also, check each one for a short to ground and short to power.
Old Jan 19, 2021 | 09:16 PM
Angel1973's Avatar
Angel1973
Ok thank u will try that. I'm sure I'll be back
Big Sky
May 28, 2019 01:55 PM
yeslekb
Apr 12, 2016 12:19 PM
juiceymustang
20
Jul 15, 2014 03:30 PM
slamed150
Nov 25, 2013 04:39 PM
Catito
Oct 11, 2006 06:53 PM
