Ignition switch spins 360degrees
over past couple days the key in the ignition switch has been hard to turn to start the truck i went out to start it today and went to turn the key and got all the dash lights on then the ignition switch started to spin freely. i can spin the whole ignition switch 360degrees and all my dash lights continued to stay on so i disconnected the battery.
i need to know if anyone has had this problem and what went wrong? im not sure if its the ignition switch or the actuator rod i know theres some gears that turn stuff inside.i have the steering wheel off but have never dug into a steering column any help would be appreciated thanks.
Actuator rod goes in slot circled in red.
If you are able to turn the lock cylinder round and round then a broken ignition actuator is most likely the problem. How to replace the actuator:
https://www.ford-trucks.com/forums/8...-actuator.html
