Alternator slip ring runout
Old Jan 15, 2021 | 06:18 PM
One Sock's Avatar
One Sock
Several years ago, I rebuilt an alternator from an early/mid 90's Ford truck. Among other things, I took the rotor to an alternator shop and had them put new slips rings on it. After I put it all back together, I had the shop test it on their run-up machine. It's been sitting around ever since as a spare.
Recently, I'd been getting suspicious of the old, ugly-looking alternator in my dad's truck. Today I finally got around to doing something about it. I took it out, popped the regulator off, and sure enough the brushes are on their last leg. I grabbed the rebuilt spare and took its regulator off just to make sure everything still looks OK after sitting all that time. The slip rings looked slightly corroded so I spun the rotor by hand and cleaned the rings with Scotch Brite. To my surprise, I could feel a noticeable runout on the slip rings. Looking closely, I could see that the rotor itself did not have runout, but only the slip rings.
Did the alternator shop do bad work installing these slip rings? Are the rings faulty? Is some runout acceptable, or is this a time bomb?
Old Jan 16, 2021 | 01:29 PM
Franklin2's Avatar
Franklin2
I don't know what the spec is, but the least amount of run-out possible is of course the best.
coolbrze
Oct 30, 2016 08:59 AM
Encho
1978 - 1996 Big Bronco
Apr 5, 2013 11:18 AM
rolltide3006
May 18, 2011 04:04 PM
Aeroman59
Aerostar
13
Dec 5, 2010 02:45 AM
