1978 - 1996 Big Bronco
Alternator not charging, help!.
Old Dec 8, 2012 | 09:17 AM
Encho's Avatar
Encho
The Southernmost Mod
Exclamation Alternator not charging, help!.
Hey guys, check this thread below, if you have anything to add I would be very grateful.
https://www.ford-trucks.com/forums/1...l#post12573016
Old Dec 10, 2012 | 07:09 AM
Encho's Avatar
Encho
Well, it's solved, I replaced the brushes and it's working just fine. Check the link for a picture of the old brushes, one was gone...
Old Apr 3, 2013 | 10:05 PM
Encho's Avatar
Encho
There are some new problems related to this, please check the other thread and share some ideas if you please... thanks!.
Old Apr 5, 2013 | 11:18 AM
Encho's Avatar
Encho
Ok, problem solved, the worn slip ring created an arc that burned the regulator. I got a new rotor (they just won't sell you the slip ring alone around here) with a new rear bearing and a new regulator and now it's all working just fine, $44 spent including labor, I took the alternator to their shop. Also added some washers (2 per bolt) under the alternator and now the sepentine belt has a perfect/tight fit.
Thanks all of you guys for the ideas and help.
jtaylor578578
Dec 18, 2018 09:24 AM
weyland426
6.4L Power Stroke Diesel
Dec 24, 2017 03:54 PM
Encho
21
Apr 6, 2013 11:25 AM
YamakidCR500
Electrical Systems/Wiring
Feb 11, 2011 09:09 PM
Don2
Jan 17, 2007 05:05 PM
