BEST Manual hubs?
BEST Manual hubs?
want to install better manual hubs which do you all prefere? WARN, Superwinch, Mile Marker?? any problems with any of these? which is most easiest to install? thanks for the advice
-bigdawg
'03 FX4 F250SD SC Long Bed 5.4L
other ride- John Deere 8210 185hp DRW MFWD
-bigdawg
I personally use the Warn Standard hubs. I couldn't justify spending 40 dollars more for a metal **** vice a plastic one. It cost me roughly 86 dollars for the Standard hubs. Add 18 dollars for a set of snap ring pliers and some axle grease to do the conversion, and I still came out less than the Premiums cost. Over here in San Diego about 130 dollars. The plastic **** is pretty thick. I can see it getting brittle over time, but that is at least a few years away. Just keep fresh grease on them every now and then and they (either premium or stanard) will last a very long time.
My WARN standards have been on since the truck was 5 years old everything is still in perfect working order and condition...plastic ***** and all! IF they do ever wear out I will more than likely replace them with Premiums because I prefer the 3/4 turn design over the 1/4 design.
My F250 still has the factory hubs, which are none other than Warn Standards with a red plastic dial...
For my 81 F100, I got some Premiums, the 9/10 turn engagement is more to my liking than the 1/4 turn(plus, the 1/4 turn hubs are near impossible to turn when it's -40....)
Hubs are cheap - use them like a fuse.
I look for weak hubs. A broken hub is like a fuse in a circuit.
If I'm stressing the drivetrain to the point that standard Warn
hubs break, let them break.
It's cheaper to buy another pair of hubs (and now you have a
spare for next time!)
Hubs are cheaper than axles, diffs, etc.
Easier to replace than U-Joints, and less risk of secondary damage.
