Killer compressors
Old Jan 13, 2021 | 11:39 AM
Yahiko's Avatar
Yahiko
Killer compressors
When was the last time you looked at the bomb sitting in your shop?
Old Jan 13, 2021 | 01:10 PM
ford390gashog's Avatar
ford390gashog
For most people never! Let alone drain water. Most compressors also have very thin tank walls in the light duty class. I have also seen plenty of pressure ratings exceeded and tank safety releases replaced with pipe plugs. I have been doing pressure vessel inspections for decades in the industrial sector and there is no lack of surprises. I have seen tanks so rusted they still passed a hydro test but fail a visual. On the other hand I have seen clean tanks pass visual but fail hydro at just 10% over rating. The amount of stored energy is unbelievable in a pressure vessel and its not often you walk away from a failure unharmed.
Old Jan 13, 2021 | 01:19 PM
Yahiko's Avatar
Yahiko
The one place we see a increased risk in onboard compressors and storage tanks on our trucks.
I would bet that those little tanks get ignored more than the larger units that sit in shops or under
a bench out in the garage. That is not even taking into account the really cheap tanks from China.
Old Jan 13, 2021 | 01:33 PM
TooManyToys.'s Avatar
TooManyToys.
I've been looking at replacing mine for the last few months. I replaced one at the test facility that was made by our company when they were making them. The unit was from the '40s but massively heavy due to the tank wall. The electric motor was crazy built too.
I've drained mine routinely but always amazed at how much water is in the tank. I'll have to go back in and record the video from a borescope inspection.
Old Jan 13, 2021 | 01:41 PM
ford390gashog
The next issue on light duty compressors is self induced. These compressors use very cheap 3450rpm motors and often the pumps are direct drive or sheaved to run the pump above 1800 rpm. This creates massive heat and the water turns to vapor and condenses in the tank quickly. This is why you see very little moisture on industrial compressors in the tank especially when pump speed is below 800rpm and often at 680rpm. These pumps don't super heat the air like the low displacement high rpm pumps. My personal shop compressor is a Quincy 375 Pump that runs 550rpm and moisture in the tank is never a issue. I do have a auto drain set for every 60 min which helps but the pump never gets very hot even on the second stage.
Old Jan 14, 2021 | 12:46 PM
Hartwig's Avatar
Hartwig
Old Jan 16, 2021 | 08:54 AM
F350 1990's Avatar
F350 1990
I use auto drains on tanks because (as a welder) I see PLENTY of chitty welds on almost all tanks I look at.
The non-destructive tests they use at the factory only work when new. ALL tanks have problems with water / moisture over time, then you get the destructive tests (pictured above). Tanks are like concrete over time (99.9999% of it cracks).
Old Jan 17, 2021 | 07:06 AM
87crewdually's Avatar
87crewdually
Thankfully I'm never hugging my 60 gallon compressor tank. And it gets drained of water every day I'm done using it. On the truck OBA tank it is drained every time I service the truck and barely a half of a teaspoon of water comes out. I'd like to think most others do the same. Maybe not.
Old Jan 17, 2021 | 07:19 AM
bismic's Avatar
bismic
Totally agree. I never leave water in it. Drained at the end of each day and left open. Doesn't take that long to get the compressor 'fired up" at the beginning of each day I am going to use it.
That said, my portable tank I carry in the truck is stainless.
Old Jan 17, 2021 | 08:41 AM
TooManyToys.
I do the same, drained at the end of use and depressurized. I shut off the power, open the drain, and let it all bleed down that way. I replaced the original valve with a 1/4 turn Swageloc stainless, extended it to the side. There is no reason to leave a potential bomb for the wife or firefighters.
It's interesting in Sean's added video that it blew down the seam.
Old Jan 17, 2021 | 04:35 PM
Yahiko's Avatar
Yahiko
Old Jan 18, 2021 | 05:58 PM
Bitterroot Diesel's Avatar
Bitterroot Diesel
Former Vendor
We use auto drains and a chiller feeds all the air to a propane tank for air storage. Each machine has it's own filter and regulator.
Old Jan 20, 2021 | 02:01 PM
FiveOJester's Avatar
FiveOJester
Jack, the stresses along the length of the tank are 2x the "hoop stress" around the tank circumference. So unless there is a really weak spot at the hoop, it will always break down the seam.
Good example is micro-waving a hot-dog. Always splits down the middle, doesn't blow the end off.
Old Jan 20, 2021 | 02:33 PM
TooManyToys.
I was just pointing it out.
I'll add IMO weld seams are usually the weak point, not the weld itself, but the material next to the weld gets annealed and the crystalline structure is altered. Same as doing the stupid move of hardening the base material for a valve seat.
Depending on the filler and base metal, also the potential for creating a galvanic cell (accelerated corrosion) at that location due to the dissimilar metals, as well as any oxygen concentration gradients that may have been created, or any hydrides or oxides which may have formed during the process. Not what you want in an air compressor tank, and why the good ones are more expensive. Way farther down the rabbit hole then I was intending for the comment; geez it's just a diesel forum.....
Old Jan 20, 2021 | 04:44 PM
Yahiko's Avatar
Yahiko
Jack your forgetting that it's not just a Diesel Forum but a Diesel Truck Forum.
There are quite a few people out there that put a compressor in the trucks.
There are some out there that have put the small cheap tanks in that run the risk
of a tank failure.
