Front leaf spring recommendations
Old Jan 10, 2021 | 07:26 PM
Ed in Maine's Avatar
Ed in Maine
Finished the rear rebuild with these on each side: 4/1 = 5 Leaf, 2-1/4" think, 3" wide, 2810lb Per Spring Rating (not too firm actually, seem nice)
Factory over load springs on top, I think they are 800lb ea?
It is sitting a bit higher now but I have been planning to do something in the front to help with the plow.
I noticed these BDS 2-3" front add ons, here.
Anyone have other recommendations? 2-3" should be good.
Old Jan 10, 2021 | 07:51 PM
97-psd's Avatar
97-psd
Dad has something similar on his truck. It is pretty similar to yours (regular cab 350). It does not drive bad per say, but it is pretty stiff. If you want it to ride well, I would either do new springs or a shackle reversal. Granted, both are more $$ than the add a leafs, so it will depend on how you use the truck, and how you want it to ride.
if you choose new springs. Check out ATS. They are supporters here and everyone has great things to say about them
@ATS Junior
Old Jan 10, 2021 | 08:23 PM
Ed in Maine
Good info, thanks. This will be just for hauling and plowing.
May end up with new front leafs up front but don't want to go too high.
Old Jan 11, 2021 | 06:09 AM
Edgethis's Avatar
Edgethis
I agree that new leafs will be much better then an add a leaf option. An rsk is nice but that adds to the cost as well. The rsk bracket is about 400 and then another 400 or so for springs. The SD does has alot of options for spring weight though. My supercrew cab rides very up front with the new springs....then the rear (stock springs) hits and I feel like I've been kicked in the back of the seat.
Old Jan 11, 2021 | 08:19 PM
Ed in Maine
Did a test drive this evening with the new rear end. It goes down the road better than I expected, even on these heaved ME roads. The front end is in need of some love and i agree, new springs are definitely to be considered.
I just want it to level up at least 2" higher, but also not sag too much with plow hanging off the front.
Open to and appreciate any recommendations for springs, with or w/o the RSK/
Thanks!
Old Jan 12, 2021 | 07:26 AM
Edgethis's Avatar
Edgethis
An rsk raises the front end by about 2" at least. They make ones with more lift up to 4" i believe. I have V code springs on my truck, alot of folks go with U code but with a plow I think you might want v or even x. They have a higher capacity and will also affect the height.
GoldCo
Jul 5, 2019 06:54 PM
buck_
1978 - 1996 Big Bronco
Oct 26, 2010 11:40 PM
jor1369
Apr 8, 2005 10:32 PM
oft
Dec 24, 2003 03:44 PM
Big Red 75
Nov 21, 2003 09:47 AM
