leaf spring support
Old Apr 8, 2005 | 09:25 PM
jor1369's Avatar
jor1369
leaf spring support
Hello,
Can someone help me out. I just saw a truckstv show and they showed a rear leaf spring that is only active under heavy load. I can't remember whats its called or from what company. You just add it to your leaf springs and when you put extra weight, the support spring prevents the truck from sagging down.
Can someone tell me what its called or where to get it from. Thanks
Old Apr 8, 2005 | 10:32 PM
tex94F250's Avatar
tex94F250
It's a helper spring if I am correct. Looks like a leaf with two u-bolts at each end that go under the factory springs? If so they are available from JC Whitney, a forum sponsor. Hellwig makes the Load Pro sold there. jcwtruck.com.
