4 Lo problem
Old Oct 24, 2003 | 10:10 PM
palomo1152's Avatar
palomo1152
Question 4 Lo problem
I know that you are not supposed to use the 4wd lo unless you are stuck in the snow or the mud, or in an extreme situation, but the other day i tried to turn it on to see if it works, and it did not even light up. I was wondering if it was a problem or if it didn't come on because i didnt need to use it, any help would be appreciated
Old Oct 24, 2003 | 11:27 PM
FortyFords's Avatar
FortyFords
If you were not stopped with your foot firmly planted on the brake ,it will not go to 4lo.
There are safety reasons why this has to happen,before the transfercase will not shift to lo
Rich
Old Oct 25, 2003 | 12:10 AM
mrshorty's Avatar
mrshorty
You also have to have the transmission in neutral (P isn't even good enough) and have to be almost completely stopped ( I think the t-case module will accept <3mph, but at that point, with your foot on the brake, you just as well be stopped.)
If that doesn't get it to shift, then the next likely problem is a dirty shift motor (quite common). There are a few places on the net (www.ford-trucks.com has one) that describe how to take the motor apart and clean it up.
Old Jan 3, 2004 | 12:59 AM
ohfugit's Avatar
ohfugit
If its a manual trans you have to have the clutch pushed in as well... I thought mine was hosed as well until I got the owners manual...
90'F150
Jun 12, 2013 09:19 PM
Keymaster
1997 - 2003 F150
Jun 11, 2006 11:10 PM
jimbob21rc
Offroad & 4x4
25
Jun 11, 2005 06:16 PM
hoxiii
Offroad & 4x4
33
Aug 15, 2004 06:21 PM
unluckylow
Apr 9, 2004 07:46 AM
