No 4lo
Old May 28, 2013 | 09:41 AM
90'F150's Avatar
90'F150
No 4lo
Hey everyone, got a problem here. When I shift to 4hi it goes beautifully but won't go any further so no neutral on the transfer case or 4lo. Any ideas?
Old May 28, 2013 | 10:57 AM
blue924.9's Avatar
blue924.9
yeah, check the linkage for binding and grease it while you are down there
Old May 28, 2013 | 12:32 PM
Phy's Avatar
Phy
Don't know on a '90, but on the later trucks you have to push down on the shifter to go to neutral & 4Lo.
Not trying to be condescending or anything, but if it's a new-to-you truck with that shifter, you might not know that...
Old May 28, 2013 | 12:37 PM
dixie460's Avatar
dixie460
Nope, his '90 has the early shifter where you go sideways around the detent.
Try shifting with the truck rolling about 1-2 MPH in neutral. Sometimes the gears ain't lined up quite right, and unless the output shaft is turning it can be a pain to get them to mesh.
Old May 28, 2013 | 01:42 PM
Island'r's Avatar
Island'r
Yeah my old Bronco would not shift in park. Even in/out of 4 HI it would be a buggger... I always found putting it in neutral and foot off the brakes was the easiest, and it helped the gears to mesh
Old May 28, 2013 | 09:04 PM
MeanGreen460's Avatar
MeanGreen460
Try lubing freeing up linkage on transfer case
Old Jun 12, 2013 | 09:19 PM
90'F150's Avatar
90'F150
Thanks for all the replies I'm just getting this now because I'm not on too often with school and everything but I'm gonna try using the compressor to blow around the linkage I case like a piece of rust is jamming it or something and then grease it up. If worst comes to worst i guess I'll have to take off the linkage and thoroughly check it out.
ferrousFord
Jul 20, 2015 08:57 AM
Mike1
Aug 20, 2013 08:56 PM
Lefty980
Aug 19, 2013 05:51 AM
Jermafenser
May 9, 2009 07:33 PM
'77hiboy
Apr 24, 2008 07:17 PM
