Is there a Timing chain recall 4.0
I have since spoken to another shop and he said I might as well just put a new engine in! Because you should drop the oil pan, clean it all out and with all the hours and the likelyhood of it running right after the timing chain replacement you might as well replace the engine. He said the just don't run well after the timing chain is replaced especially if you don't use factory parts.
I don't know what to do.
Please help it is my only rig and I only have had it a few months.
Thanks,
Kallie
Recall issues on timing chain tensioners affects overhead cam model engines which your 92 is not one of them. Search this forum for timing chain tensioner threads to get a better picture of the affected models.
Pinging issues are also common in here. Some have fixed theirs by cleaning/replacing MAF sensor, others have had leaking lower intake manifold gaskets or loose manifold bolts that only needed tightening. Search forum for Pinging and you will see some common items.
My 91 has 240 K miles and is still on original timing chain (and engine for that matter). I have had to replace lower intake gasket due to a water leak however, otherwise, the engine has never been apart. This engine is one of the best I have ever seen in a Ford.
Dialtone
Thanks again,
Kallie
"Ping" or "spark knock", however, is a common complaint.
One common cause is a slightly lean mixture. This comes from a dirty MAF or a slight vacuum or air intake leak. As mentioned by Dialtone, try cleaning your MAF. In the official repair manuals, the MAF is considered "not serviceable," meaning that a shop may try to sell you a new one rather than clean the old one. This is a common fix for the pinging issue, so try it. Just pull the sensor out of the housing (security torx bits are ~$10 at Autozone or equivalent), gently wipe the filaments off with a q-tip and isopropyl alcohol (other solvents would work, too), and re-install.
As for vacuum leaks, make sure all vacuum hoses/connections are in good condition and not leaking. An unusual "vacuum" leak that commonly develops on these engines is from the lower intake manifold gasket. The bolts come loose, and often just tightening them down to specification is enough to seal up the leak. Dialtone mentioned this one, too. Don't ignore it. Simple (relatively) fix for a common problem.
Another thing that can cause a lean running engine and "ping" is dirty fuel injectors or low fuel pressure. Make sure fuel delivery is where it should be.
A final common cause of ping on these engines is carbon buildup in the cylinders. Several different products out there that should deal with this possibility. Seafoam is one, some just use water. As long as you follow the instructions and don't hydrolock the engine, it works well.
Considering that these are common causes that we encounter frequently on these boards, and the alternative your mechanic is giving you is a new engine ($$$), they are worth trying. Based on what I've seen, you have a good chance of fixing the problem without buying a new engine.
[BThis engine is one of the best I have ever seen in a Ford.
[/B]
Either way, yes, the SOHC motor began in 1997 DID have a recall on the timing chain tensioners themselves, but not the chain. The SOHC motor has I believe it is 4 timing chains. That motor is a nightmare to work on compared to the simple OHV valvetrain. You don't have anything to worry about with your tensioners going bad.
Pinging can be caused by a lot of things, but these suggestions from the guys are great ones. You shouldn't need to run higher octane gas. Usually that just causes buildup since not all the gas will burn off. Also, my Vulcan engine pings when I am lugging it up a hill in OD. Kick it down into a real climbing gear, it stops. Be sure not to lug the motor around.
P.S the whole job is quoted at $400. parts and labor and I also have a 1 yr guarantee. I will be going back to supervise ensuring all new parts.
Thanks again,
Kallie
