360 fe compression question
Old Dec 29, 2020 | 08:45 AM
Dent79's Avatar
Dent79
Compression ranges from a low of 140 to 170psi. I thought that those numbers are supposed to be within 10psi of each other. I guess I'm asking are those numbers acceptable or is something off.
Old Dec 29, 2020 | 09:07 AM
440 sixpack's Avatar
440 sixpack
The rule of thumb is 10% maximum difference.
Those numbers seem awful high. how did you do the test ?
Old Dec 29, 2020 | 09:13 AM
Tedster9's Avatar
Tedster9
It is better to see close or even numbers across all cylinders. Excessive carbon buildup might cause high readings in some cylinders.
Old Dec 29, 2020 | 09:19 AM
Dent79's Avatar
Dent79
Removed plugs and coil wire and used a Guage im kind of new at this im not trying to be smart, im just confused
Old Dec 29, 2020 | 09:25 AM
Dent79's Avatar
Dent79
So carbon build up from the crappy gas we get now could be the problem? The heads were worked a year ago at a local machine shop probably put only 500 miles in a year the truck sits alot.
Old Dec 29, 2020 | 11:30 AM
Tedster9's Avatar
Tedster9
Well no, in some ways modern gasoline is better at least in terms of carbon and sludge buildup than the days of yore. Spark plugs should burn very clean, with hardly any "color" even in older engines. If they are running rich i.e. carboned up, the carburetor isn't dialed in. If extreme carbon is built up in the combustion chamber that might contribute to a skewed compression reading. How do the plugs look?
A high compression ratio means high octane fuel is necessary. A stock healthy factory-ish engine would only run around 150 psi on the compression and should run OK on pump gas.
Old Dec 29, 2020 | 11:47 AM
440 sixpack
Unless you changed the pistons it would take a pint of carbon per cylinder to make a 360 high compression.
Did you hold the throttle wide open while you did the test ? that should only make the compression higher but if you didn't it might explain the erratic readings.
I question your findings, but while the numbers are uneven they're all high so there's nothing you need to do .
Old Dec 29, 2020 | 11:52 AM
Tedster9's Avatar
Tedster9
That's a good point, this is all "academic", the compression is probably fine.
Old Dec 29, 2020 | 12:04 PM
Dent79's Avatar
Dent79
Thanks guys you answered my question regardless of the fluctuations the compression is still good at 140
Old Dec 29, 2020 | 12:20 PM
Tedster9's Avatar
Tedster9
For general engine diagnostics and getttng a good sharp tune, I like the vacuum gauge. It is more useful I think, a compression test is at best kind of a pain in the you know what, and a vacuum gauge is just a whole lot quicker and will more or less indicate cylinder compression as well.
Notice every Tune-Up manual ever published since about 1915 has "vacuum test" as #2, right after the compression test. The idea generally is to check cylinder compression first, and see if the engine is lunched and worth mucking around with, if it fails badly that usually, not always, means further Tune-Up, buying parts, is pointless because it will never run very good. Most engines will run very well if tuned up correctly so long as there are no major internal engine derangements. The one caveat to keep in mind is engines that have been sitting a long long time. Gum and varnish will tend to stick rings and show almost no compression. A solvent can really help with this.
bigreed91
Apr 28, 2016 11:38 AM
Hercules
Mar 30, 2012 08:19 AM
bulla
Apr 24, 2011 07:30 AM
390Highboy
Nov 4, 2006 04:40 AM
raymechanic
18
Aug 27, 2005 06:12 AM
