390 displacement question
Old Nov 3, 2006 | 08:17 PM
390Highboy's Avatar
390Highboy
Question 390 displacement question
If my 390 has been bored .060 over, what is its displacement now? Does anyone know the formula for this? Also, if i am running about 130 lbs of compression on each cylinder is there a way to calculate the compression ratio?
Old Nov 3, 2006 | 08:42 PM
baddad457's Avatar
baddad457
402 cubic inches. Bore radius squared, times Pi (3.1416) times the stroke, then multiply times the number of cylinders. If you want to convert to cc's to figure the comp ratio, multiply the cubic inches times 16.387. Example: 4.05/2 = 2.025, then 2.025 X 2.025 = 4.100625( X 3.1416) = 12.8825. 12.8825 X 3.78 = 48.6959. 48.6959 X 8 = 389.567.
Old Nov 3, 2006 | 10:26 PM
390Highboy's Avatar
390Highboy
Thanks, that helps a lot.
Old Nov 3, 2006 | 10:52 PM
Redmanbob's Avatar
Redmanbob
very much thats very helpful. Thanks again.. wont loose this info anytime soon. link saved and a copy in text doc... Gracias!!!
Old Nov 4, 2006 | 12:14 AM
"Beemer Nut"'s Avatar
"Beemer Nut"
Bore x bore x .7854 x stroke x 8.
Old Nov 4, 2006 | 04:40 AM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Bore and Stroke calculator!!! LOL..
RJ
BelJask
May 3, 2016 06:19 PM
74f100sc
15
Feb 23, 2016 11:26 PM
ScallyWaggler
May 16, 2015 02:03 AM
penn
19
Mar 29, 2003 07:17 PM
big block power
Sep 3, 2002 02:30 PM
