Excursion v10 possible pcm problems
Old Dec 28, 2020 | 11:17 PM
MeTodd's Avatar
MeTodd
So the other day my 2000 excursion v10 overdrive light starts flashing (which usually means death of a trany) . But what’s weird about this is all the sudden the engine starts missing , won’t except throttle (except in second gear) , didn’t have first gear , banged into drive hard . So long story bearable, In a single event I went from no codes to over 20 codes not all transmission related . Lean bank 1 , lean bank 2 , bad evap system, all shift solenoids not working , torque converter locked , ect. 17 codes on one of my testers and 30 on the more advanced one . I’m thinking pcm????
Old Dec 28, 2020 | 11:42 PM
MasterX's Avatar
MasterX
MUST GO FASTER!!!!
did you kick a leprechaun through a mirror that was under a ladder or something?
Old Dec 28, 2020 | 11:49 PM
MeTodd's Avatar
MeTodd
[QUOTE=MasterX;19649428]did you kick a leprechaun through a mirror that was under a ladder or something?[/QUOTE
That’s what I’M saying ....... what the heck ?!?!?
Every ONE of the codes said “from pcm” ?!?
Old Dec 28, 2020 | 11:55 PM
MasterX's Avatar
MasterX
MUST GO FASTER!!!!
done any, and i mean ANY, wiring, radio work, modding in the last few months? if so go into extreme detail.
checked all the fuses? any blown, list their numbers. and even post a pic indicating them if possible.
Checked battery voltage when off and when running? if so post them.
Alternator Tested? Battery Tested? Alternators can cause crazy **** to happen when they **** the bed in certain ways.
Give us the complete list of codes you are actively popping, even if they look BS, let us be the judge of that, because sometimes it helps to understand, as one problem can actually cause false symptoms of another, so leave nothing out.
Old Dec 29, 2020 | 12:02 AM
MeTodd's Avatar
MeTodd
I haven’t tested alt. yet . I’ve done no modifications recently except shocks and brakes . I’ll have to check alt & fuses after this event .I’ll do that and list my codes as well . Thanks - to be continued ....
Old Dec 29, 2020 | 12:08 AM
MasterX's Avatar
MasterX
MUST GO FASTER!!!!
Shocks and brakes, including the booster/master cylinder or just the rotors/pads/calipers, aka lower items?
Details, that is where the devil always hides?
Old Dec 29, 2020 | 12:09 AM
MeTodd's Avatar
MeTodd
lower items only . Rotors and pads. I definitely see where that can go though .....in engine compartment knocked something off or broken wires , ect .
Old Dec 29, 2020 | 06:24 PM
01__Excursion's Avatar
01__Excursion
The dreaded water damaged GEM on backside of interior fuse box?
Old Dec 29, 2020 | 07:27 PM
DSMMH's Avatar
DSMMH
Not familiar with the gas X as mine is 6.0 diesel. Not sure how many miles are on your X. I would suggest you swap the PCM power relay with another. It may be a 70 amp relay (two pins larger then others) or a standard 30/40 amp (all pins the same size). I have found that relays are the cause of many electrical problems.
FWIW, I replace all of the relays on my X annually. IMO, aftermarket relays are better then the expensive OEM relays.
Ed
Old Dec 30, 2020 | 12:04 AM
MeTodd's Avatar
MeTodd
Ed
yeah good thinking . I will give that a try .
Old Dec 30, 2020 | 06:38 AM
projectSHO89's Avatar
projectSHO89
Blown fuse (or open circuit) that feeds all of those actuators/solenoids, etc. Probably fuse F19 under the hood. Leave the rest of the fuses and all of the relays alone, they cannot cause this set of symptoms.
Don't make this more complicated than it needs to be.
Same issue: https://www.ford-trucks.com/forums/1...-blinking.html
Old Dec 30, 2020 | 09:37 PM
MeTodd's Avatar
MeTodd
so update - blown fuse 19 under the hood . That fuse triggered 17 codes on my one reader and 28 on my FORScan . Thanks for all the help
Old Dec 31, 2020 | 06:47 AM
projectSHO89
Fuses do not just blow without cause. Unless you can identify something that specifically caused it, the underlying issue is still there.
jjmills
Dec 30, 2020 10:49 PM
xplodn
28
Aug 20, 2013 09:39 AM
DarrellinCeres
Modular V10 (6.8l)
Jul 18, 2013 10:09 PM
christopherdrop
Jul 24, 2012 08:43 PM
excursion22
Mar 22, 2009 06:20 PM
