v10 trans problems
Old Nov 3, 2020 | 03:26 PM
jjmills's Avatar
jjmills
v10 trans problems
does not want come out of 1st gear un less i let off gas and hit again. maybe the shift solenoid?
Old Nov 3, 2020 | 05:56 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Maybe, but that wouldn't be my guess.
Can you run codes?
Old Nov 3, 2020 | 09:12 PM
jjmills's Avatar
jjmills
maybe scangauge 2. will check tomorrow
Old Nov 5, 2020 | 06:33 PM
jjmills's Avatar
jjmills
no codes from scanguage went to oreilly and no codes. yes the od light is flashing
Old Nov 5, 2020 | 08:02 PM
Mark Kovalsky
Then you need a tool that can read the codes. Auto parts stores cannot read these codes. I recommend Forscan.
Old Nov 6, 2020 | 10:37 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
You'll have to drive it until codes come up. Mine did something similar when the mechnical diode went out, but you will need codes to confirm the condition.
Old Nov 6, 2020 | 02:14 PM
Mark Kovalsky
If the OD OFF light is flashing there are codes stored. You just need the right tool to read them.
Old Nov 7, 2020 | 08:04 AM
EXAL's Avatar
EXAL
You can get FORScan here. Unless you need some advanced features, which I don't think you do in this case, you can just download the free windows version. It used to only run on Windows 7 but it looks like it's compatible with Windows 10 now. Just under that download link is another link for a
USB/OBD adapter USB/OBD adapter
that they recommend. From another post, it sounds like Pirate has had success with
this adapter this adapter
as well. Sounds like this tool can also help you track down misses in your V10, etc. Finally, I'd just say that Mark is the resident transmission expert here. I'd follow his advice. Good luck!
Old Nov 7, 2020 | 08:24 PM
jjmills's Avatar
jjmills
thanks to all hopefully we will get it to a place that can read codes this week also will try to do forscan
Old Dec 30, 2020 | 10:42 PM
MeTodd's Avatar
MeTodd
Hey I don’t know if you saw MY excursion problem on here but with mine , it turned out to be fuse 19 under the hood . My OD light stared flashing and my transmission was acting crazy . That #19 fuse being blown caused All KINDS of havoc . I went from no codes to 17 codes from ONE fuse . Just a thought.
Old Dec 30, 2020 | 10:49 PM
MeTodd's Avatar
MeTodd
banshee rider81
Ford Truck Parts for Sale
Mar 8, 2014 03:32 PM
WP1
Modular V10 (6.8l)
Jun 18, 2013 03:06 PM
pennsylvaniabo
Modular V10 (6.8l)
17
Dec 27, 2012 07:31 PM
blackwellsgamefowl
Jun 1, 2011 12:17 PM
V10KLZZ71S
Modular V10 (6.8l)
Dec 12, 2002 12:27 AM
