Battery Replacement Question
Old Dec 27, 2020 | 07:10 PM
America78's Avatar
America78
Hello
i have a 17 F250 XL 6.2 4x4. Battery has been turning the starter slower than usual on not too coldish winter mornings (30F or so). I am thinking of replacing battery as it’s now 39 months old. Will replace with either Diehard Gold or Interstate higher end battery. Have any of you ran into issues with having electronics not come back or have to be reset after original battery replacement? I haven’t had that issue on anything I’ve owned before, but figured I’d check here first
thx
Merica78
Old Dec 27, 2020 | 10:52 PM
minke's Avatar
minke
Write down your radio memory contents for re-programming.
Old Dec 27, 2020 | 11:02 PM
yardbird's Avatar
yardbird
I just had a new battery put in our Edge last week. It's the limited with big screen and push button start.
I went to a local battery place that not only sells cheaper than stores, but checks the old battery and installs for free, including cleaning cables and spraying anti-corrosion on them.
He plugged a battery backup into the OBD port and nothing was lost.
Best part was an 850 CCA Motorcraft battery $40.00 cheaper than AutoZone's 850 CCA battery.
Old Dec 27, 2020 | 11:23 PM
cpobst's Avatar
cpobst
I pretty much shop battery warranty more than anything.
Old Dec 28, 2020 | 04:41 AM
seville009's Avatar
seville009
I’ve never lost any settings when changing batteries - done on 2016 Edge, 2011 F350, 2019 Explorers.
Old Dec 28, 2020 | 06:58 AM
Oldstyles's Avatar
Oldstyles
Amazon Amazon
This (with a small battery) provides voltage to the vehicle while you swap your main battery.
Old Dec 28, 2020 | 09:36 AM
minke's Avatar
minke
Perhaps the radios have non-volatile memory now. I'd prefer to be wrong on this,
Old Dec 28, 2020 | 06:21 PM
America78's Avatar
America78
Thanks all!
finnf250
Dec 22, 2020 07:54 PM
GreenHornet79
General Automotive Discussion
Dec 11, 2005 08:18 PM
ET1
Electrical Systems/Wiring
Nov 3, 2004 10:50 PM
MOOK929RR
20
Jun 30, 2004 12:59 AM
triton_2002
1997 - 2003 F150
Sep 21, 2003 01:44 AM
