E40d problems
Old Dec 24, 2020 | 07:24 PM
Brannon Sanford's Avatar
Brannon Sanford
E40d problems
Ok guys im having this issue with my transmission when you put it in drive and go the tranny shifts hard into 1st gear it feels almost as if someone is pushing you from behind and after that 2nd 3rd and 4th are fine but it also slams into gear when you put it in reverse and sometimes in drive, I've recently put in a new torque converter and made sure the fluid levels are perfect anybody got any idea on whats going on? I was thinking the solenoid shift pack or that the transmission is about to go out and needs replaced or rebuilt
Old Dec 24, 2020 | 07:56 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Before spending a bunch of money you should read the codes. It might be something cheap and simple. If I knew what your truck was I could tell you how to read the codes.
Old Dec 24, 2020 | 08:00 PM
Brannon Sanford
Its a 95 f150 2wd with the 5.8 as.of right now it isnt throwing any codes but also I know those older vehicles didn't always flash a check engine light for everything like the way the newer vehicles are today but yes I will do that I know I can do it with a paper clip and count the blinks am a right?
Old Dec 24, 2020 | 08:37 PM
Mark Kovalsky
Yes, you're right. www.troublescodes.net/ford
Old Dec 24, 2020 | 08:50 PM
Brannon Sanford
Thanks ill be busy tomorrow but will get to it on sunday
Old Dec 24, 2020 | 10:42 PM
wwhite's Avatar
wwhite
Any change from how it shifts compared to the old torque converter?
Is that a brand new or rebuilt torque converter, or a used/new to you torque converter?
How does the fluid look and smell?
Old Dec 25, 2020 | 09:52 AM
Brannon Sanford
Fluid looks and smells fine it was a.$200 power torque converter reman
Old Dec 25, 2020 | 12:25 PM
wwhite's Avatar
wwhite
Your issues are more than likely internal to the transmission, probably needs to come apart and inspected.
Or, does your truck have a trac-loc/limited slip rear end?
My truck slams into first and reverse, cause is worn out clutch pack in rear end.
It echo's through the drive shaft, a distinct rear end sound, and I did question the transmission as the issue.
Old Dec 25, 2020 | 03:09 PM
Brannon Sanford
The rear end is actually fine I replaced all bearings and seals about 9 months ago but im going to diagnose it first old school way with a paper clip and counting the blinks to see if I'm throwing any codes
Old Dec 26, 2020 | 11:33 AM
F350 1990's Avatar
F350 1990
Thumbs up
OP -- I've had plenty of these and quite a few on the bench / torn down -- they can work, do have their share of problems (early versions are the worst mess known to modern man), but can serve you well with upgrades (Ford's done a ton over the variants and frankly Ford's transmissions are in many ways best in class when compared to the REAL CHIT from other manufacturers like 518s, 47REs, 48REs from Mopar as examples).
Here's a decent tool to help:
https://download.cnet.com/E4OD-Free-...-10537137.html
Old Dec 26, 2020 | 04:35 PM
ryan73ford's Avatar
ryan73ford
Try taking a peek at your Transmission Range Sensor, or Neutral safety switch (same thing). My trans was acting very weird and that was the culprit.
Old Dec 27, 2020 | 11:32 AM
65f100_352's Avatar
65f100_352
I had the same exact problem, 1-2 shift would slam hard as could be, and I replaced the range selector on the side of the transmission.. no hard shifts since then
mikerans
Aug 8, 2011 09:59 PM
MPlayer
Sep 3, 2008 09:00 AM
Fire85
Nov 27, 2007 11:14 PM
